Brasssyslv, There are three bolts holding the bar in place. Two in front and one in the back. To get at the back bolt, remove the plastic triangle shaped cover by pulling it straight up. When you remove these bolts, grab the bar and turn it 90 degrees either way and pull it straight out. Now the only thing holding the fuse box in is either a 10mm bolt or a plastic push pin. Remove it and place the box aside while you change the battery. Good luck with this.
