I have a 57 inch zenith hd tv and just recently i started to get a double picture and i was told it wasnt the picture tube what could it be.
  • Anonymous Dec 08, 2008
    I have a double picture
  • 125 Answers
No it ie not the picture tube thereis a module inside the tv that needs to be replaced. convergence module it's about $100.00
+ labor
Thank you
JOSE
Posted on Aug 17, 2008
SOURCE:
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Sep 22, 2009 | Zenith R57W46 57" Rear Projection...
My Zenith Projection HD TV is displaying a series red lines
It probably needs the convergence circuit repaired by a qualified technician.
Sep 09, 2009 | Zenith R57W46 57" Rear Projection...
Sony wide sceen projection tv kp-51ws510, my picture looks like 3 dimensional pictures , with a red highlighted all around the picture,how can fix this?
hi
this type of problem occurs because of 3 issues..
1.colour wheel
2.jungle 45e3 ic on D- board
3.cathode ray tube...
check them...
thank u..///please rate it
Jul 04, 2009 | Zenith R57W46 57" Rear Projection...
Old tv's
I dont think you need a picture tube. If the audio still works when the picture goes out I would suggest checking the solder on the vertical output IC that could make the picture tubes blank out. Look for hairline cracks and resolder just to make sure. Let me know how you make out or if you need more info.
Mar 13, 2008 | Zenith R57W46 57" Rear Projection...
Zenith Blurry Picture
i got a zenith tv and the picture is really blurry how do i focus it ?
Feb 02, 2008 | Zenith R57W46 57" Rear Projection...
Picture flashing
If it is an older "hd" tv it is probably 'hd ready.' Check for adjustments on your source. The tv will most likely only display the highest resolution it is given.
Dec 28, 2007 | Zenith C27V36 27" TV
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
