Televison & Video Logo
Posted on Jun 01, 2011
Need codes for parker tv to programme my directv remote to wok with my tv
Felipe Hidalgo
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 04, 2015
Felipe Hidalgo
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
8691
Points
7
Parker TV will work under TCL (Brand) codes.
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Dec 29, 2009
SOURCE: i need a code for dynex tv to work with directv remote
I tried 10463 and it worked
Dynex is a brand from Sansui made especially for Best Buy......hope it works for you also!!
Anonymous
  • Posted on May 29, 2008
SOURCE: Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Anonymous
  • Posted on Feb 13, 2010
SOURCE: Remote code Directv
try vizio under tv tv brand in the direct tv remote control codes.
tip
Polaroid TV DVD Combo Remote Codes Can't find a code to program your universal...
Can't find a code to program your universal remote to control your Polaroid HDTV / DVD combo? Can't find a listing for Polaroid DVD in your remote control code list?
Many manufacturers recycle remote control codes, so often the best solution is to use the code search function of your universal remote.
Here are some remote control codes that have worked to control Polaroid HDTVs:
  1. My 19" w/DVD uses the following Mitsubishi code: 10178
  2. Dish Network remotes: 627, 659, or 688
  3. DirecTV RC64 remote control revealed a code of 10835. This means that 10835, 0835, 835 or some variant many work with many programmable remote controls. On my DirecTV DVR system, this was indicated as a Moxell and/or Motorola TV code.
  4. Use the mitsubshi tv codes they worked for me.
  5. Try Element codes if they are listed in your remote code list.
I hope that helps.
_____________________________________________
Polaroid HDTV Manual Download
Polaroid HDTV Service Manual Download
on May 02, 2010 • Televison & Video
tip
Polaroid HDTV Remote Codes Here are some remote control codes that have worked...
I hope that helps.
on May 01, 2010 • Televison & Video
I have a diretv remote but need to programm it 2 a sanyo tv
There is a manual for the Direct TV remote and a code sheet. They should have given to you when they hooked it up. If not, look on their website. Find the code for Samsung tv and enter it.
2helpful
Can not get the directv universal remote to work with my older
I can help you with your Sony TV & DirecTV remote control.
This is a list of all the Sony TV control codes for DIrecTV remote controls:
10000, 10810, 10010, 10011,
10080, 10111, 10834, 11317,
11685, 11904, 11925, & 10505.
There are so many codes to try for Sony TVs and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
2helpful
Direct tv remote to visio tv
I can help you with your Vizio TV & DirecTV remote control.
This is a list of all the Vizio TV control codes for DIrecTV remote controls:
11758, 10864, 10885, 11499, & 11756.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
I lost my remote and need to switch the tv so I can get Directv - how can I do this without my remote
I can help you with your Toshiba TV & DirecTV remote control.
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, 11971
I hope that helps.
1helpful
I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
Top Universal Remote Control Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
