Question about Saeco Royal Professional Espresso Machine
No steam and ventilate
Okay, none of the on line solutions quite work. I have a Saeco Comfort Plus machine and it does not give out any steam. It started by the steam coming out very slowly and then the ventilate message appeared. I pressed the hot water while the steam was on and again while it was off. It comes back and steams for a little while (almost no pressure) and then the ventilate appears again. I tried some of the solutions to remove the water tank and trying to pump through water using the plastic pump and this did not work either.
Prior to all of this, the coffee was coming out slowly (it was inconsistent). We brought it to an authorized dealer to get this looked after and he said that he had to clean the machine (cost me $200 CND). Now this. Can you help?
  • beanieboy May 01, 2009
    I've got a Saeco Royal Digital Plus and the machine says ventilate. No steam, no hot water, no coffee. Tried to descale through the machine's function but no water goes through either. Please help. I'm desperate for a cup of coffee from this machine.
    Problem Solver:
  • 11 Answers
This sounds like you need a very heavy descale. I would use a regular dosage of descaling solution (citric acid) but with 3/4 of the recomended water in the solution.
With excess scale build up the vibrating pump cannot pump water through the water circuit in sufficient volume.
You can use your machines descale function or simply pour off 1/3 of a cup of desale solution though yuor water circuit then leave the new solution site for 5 minutes and repeat until you have drained your water tank.
Here is a great article on how to descale your Saeco Coffee Machine.
Saeco Coffee Machines
Posted on Aug 19, 2008
  • 515 Answers
When you try to get out water, can you get a full cup of water or just a half cup?
How often do you descale your machine?
Posted on Aug 17, 2008
How do I ventilate my Saeco Magic Plus?
Open the steam/ hot water tap ie: run hot water through the steam wand.
Dec 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
How to ventilate Saeco Magic Comfort + coffe maker
If its a Magic Comfort + there is a water button on the panel (with the drop) that you push for water. You twist the dial for steam only.
If its a Magic Delux you twist the dial for water.
Nov 21, 2010 | Saeco Magic Comfort Plus Espresso Machine
The word "ventilate" shows on screen and it won't make coffee
You can turn the water knob and let it pour out some hot water from steam wand. If your machine does not have any problem with scale the the masage ventilate will go away and work normal again.
Good luck tahnks for voding
Aug 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
On the screen is the error message - ventilate- wjat do I do?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
May 15, 2010 | Saeco Magic Comfort Plus Espresso Machine
I am getting a VENTILATE message. How do I clear this?
Open the hot water wand and dispense about a ounce or until message clears.
Aug 10, 2009 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus machine has message "Ventillate" how do you clear this?
open steam knob and water need start going on steam wand keep going couple minuts and you will see machine is ready,if you still have same problem thats mean your flowmetar is not good
Aug 03, 2009 | Saeco Magic Comfort Plus Espresso Machine
"Steam" function not working properly on Saeco Magic Comfort Plus
Most likely the nozzle is plugging up. Use a piece of wire and run it through the nozzle a few times.
please mark this answer as a fixya
Mar 18, 2009 | Saeco Magic Comfort Plus Espresso Machine
Ventilate message stays on
ventlate means run water through the steam pipe
like make water for a cup of tea
Sep 21, 2008 | Saeco Magic Comfort Plus Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Saeco Royal Professional Espresso Machine Logo
366 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
