Question about Rangemaster 110 (Gas) Kitchen Range
Auto stuck on
Did you get your oven to come on.mine has just stop working i can alter any of the buttons on the panel and it is stuck on auto.can you tell me a solution. thanks angela
  • harrygolf25 Sep 24, 2008
    have tried what you suggested and still not working
  • tinling Oct 30, 2008
    My 10 year old Rangemaster110's clock/timer constantly flashing or stuck on auto so ovens won't light. Hit or a miss to get it reset and ovens to work. Easy to get replacement and fit myself?
    Help!
You can try pressing the + button 3 times. It worked for me. Afterwards you migt need to hold the two buttons down on the left for 6 seconds then press the + button. Good luck.
Posted on Sep 20, 2008
Twin ovens stopped working
Hi, Have you altered the time clock on the cooker? It is possible that the clock/timer is set for 'Auto'
Dec 26, 2013 | Caple Ovens
There was a power cut in the house and when the oven came back on the timer works apart from the 'end' time button, this is retaining the actual time. I've tried pressing the - button to get it back to...
A simple try you can do is to turn off the circuit breaker to the oven from your breaker panel. Wait about 3 minutes or so then turn it back on. This should hopefully "reboot" the oven panel.
I hope this helps! :)
Jan 13, 2011 | Electrolux EOD6330 Ultrafan Electric...
KESA907P Electric Kitchen Range: Oven comes on but the off button will not work. H...
It sounds like it could be a stuck off/cancel button on the touch panel. When you push the off/cancel button does it feel like the other buttons or different. Usually when these buttons get stuck the proper repair is to replace the touch pad. Some of the newer ranges will produce an error code on the display when a touch panel button is stuck but not always. Unplugging the power to the range might work for turning off the oven but is not recommended. If everything else is functioning properly except for the off/cancel button then it sounds like the touch panel may need to be replaced.
May 03, 2010 | Kitchen Ranges
Kleenmaid Scala Oven. My oven will not turn on.
I had exactly the same problem. I followed the directions to reset the clock. That is the cooking button and finish cooking button. They look like a caserole dish and a casserole dish with a cross through it. Hold them down at the same time and the + and - button to advance the time. Be aware I had to try this a few times before it worked. Hope this helps, Dean
Apr 06, 2010 | Ovens
The "cancel" button for the upper section of my maytag gemini gas range no longer works. I used it yesterday and in order to get the oven to turn off, I had to unplug the range from the wall. Help!
Mine was doing the same thing. It was a stuck button under the touch membrane. If you are slightly mechanical you can fix it yourself, by first unpluging the oven from electrical power. Remove the upper panel, by taking 2 screws in back off. Also 2 screws on bottom. You can now tilt the upper control panel down to get at the controller itself. I removed it and unstuck the button. Works fine now.
Aug 09, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Flashes F7 then stops working
You have a stuck pad on the control board. Push every button several times to try and clear it. If that does not clear the stuck pad you will have to replace the electronic control.
Jun 24, 2009 | GE JKS05 Electric Single Oven
Samsung syncmaster 720 n
Is the auto adjust button stuck?
May 09, 2008 | Samsung SyncMaster 720N Monitor
Rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Apr 05, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Rangemaster 110 (Gas) Kitchen Range Logo
221 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
