Question about NexxTech NWOMMI Mouse
Changing the AAA Batteries
It looks that the signal is getting week and I want to change the
Batteries, but lost track of the manual, and forgot how I did it the
last time.
    Problem Solver:
  • 7 Answers
To change the batteries all you have to do it pull the cover off and switch them out. After that just hit the connect button on the usb connector and then click the connect button the the mouse and away you go.
Posted on Dec 01, 2008
How do I change the batteries in the Zhu zhu pets?
Changing the Batteries
A. Turn the pet over and unscrew the
motor box
B. Remove the motor box.
C. Replace the two AAA batteries matching the
polarity shown inside the battery compartment.
Be sure the batteries are firmly seated.
D. Replace the motor box and screw snug.
Jan 05, 2015 | Cars & Trucks
Wont turn on
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you. You are having problems because you calculator won't turn on. I think you should try changing the batteries. Did you know that your calculator has two batteries powering it? Not only are the 4 AAA batteries powering it, but there is also a CR 3V Lithium Back Up battery powering it as well. First, try changing the 4 AAA batteries. If that still does not power your calculator properly, you will need to replace the lithium back up battery. You can find this at a department store or store that carries electronics. To do this, open your regular battery compartment. Above the AAA batteries is a compartment that says "BACK UP BATTERY CR1616 OR CR1620" with a picture of it. Use a small crosshead screwdriver to open the compartment. Take the old battery out and replace it with the new one. Rescrew the lithium battery compartment back on and close the AAA battery compartment. Turn on your calculator and see if that works. I hope this solution solves this.
Sep 27, 2011 | Texas Instruments TI-83 Plus Calculator
My ti-83 plus is only 2 years old max. i tried turning it on one day in class and it didnt work. i've replaced the AAA batteries twice and the back up battery and i've had no luck. i tried changing the...
Try resetting the calculator. Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries and turn the calculator on. You may have to adjust the screen contrast again.
Mar 14, 2011 | Computers & Internet
I need to locate an owners manual and replacement charges for the BellSouth 1010 2 Way Radios. Our CERT group just had 26 of these 2 way radios donated to use for our training but they came with no manuals...
I have found this manual for the Bellsouth 1010
www.michaelknows.com/electronics/walkie-talkie-manual/
There is no picture to confirm it describes the correct model, but hopefully it will help.
As to a charger there is one on eBay for an unspecified piece of Bellsouth equipment.
Description: AC ADAPTER CHARGER. BELLSOUTH. Model HB-35US-01. Input 120 VAC, 60 Hz, 5 W. Output 9 VDC, 300 mA. Output connector measures 0.216", center hole measures 0.095". Center hole is negative.
It looks to be available here www.sportslinkup.com/shop/0-300ma-ac-10-NEW.html
9volts DC at 300ma looks to be a suitable voltage and current to charge 4 AAA cells.
If it looks to fit you could purchase one for proof of concept. Try it out one one that is lacking in some way, and see if it charges 4 rechargeable AAA batteries. If it does not look like it plugs in, and the handset needs a cradle to charge, forget it, as I don't even know if you have a budget, and consider plan B.
If they are only to be used for training purposes you could consider running off batteries, changing them when flat. You could go through a huge number of alkalines, so rechargable might be advisable.
I don't know what you can get locally, but I get rechargeable batteries and chargers from China offeBay at ridiculously low cost, pity about the 2 to 3 week postage delay.
It's a rough and grotty solution, but may do for proof of concept.
And who knows? I'm in Australia and like the free postage options, you may be able to do better.
Jan 30, 2011 | Audio Players & Recorders
Does using regular batteries effect the screen
No, you can use any AAA batteries, just make sure that they are all the same brand, using different brand batteries in combination may cause leakage from the batteries.
if the batteries are low, it may effect the screen, changing to a new set of batteries should improve the screen.
Sep 20, 2010 | Texas Instruments TI-83 Plus Calculator
Batteries need changing about every 2-3 weeks !!
Three options
1. take out the batts, press every button twice and put new ones in
2.call logitech and see if they will replce it
3. take that baby back to the store and get a new one
Jan 24, 2009 | Logitech HARMONY 659 Remote Control
There in no green light on RS 120. There is a red light on indicating that the headphone is being charged. Why I cannot use non-chargeable AAA batteries?
The green light only comes on when it is receiving an audio signal.
Standard batteries will work.. if you NEVER use the charging station.. and plan on replacing them every x number of hours used.. IMPORTANT.. if you forget.. and place the headset on the charging station with standard batteries.. they will probably rupture.. and may well ruin the headset..
If you decide to replace the chargable batteries.. make sure you replace them with the right size and type..
Jan 08, 2009 | Sennheiser RS 120 Consumer Headphones
Sylvania television - no sound / lost digital signal
change antenna input to on air or antenna
Apr 25, 2017 | RCA MM32110 TV
Frozen screen ti-84+
i tried furiously blowing in to the back of mine with all 4 AAA batteries and the back up battery removed
then i left the batteries out for 2 days
it works again with really minimum use... you have to repeat the blowing and leaving out nonsense every week
sometimes you regain use by rubbing the AAA batteries back and forth while they're in place
better get a new one if you can afford it
Aug 20, 2008 | Texas Instruments TI-84 Plus Calculator
Cant get Pointer to move
It's WIRELESS. The receiver is powered by USB. The mouse needs batteries. AAA in most cases! If batteries test ok in a remote control...they should have enough for mouse.
Nov 12, 2007 | Dynex DX-WOM20 Mouse
NexxTech NWOMMI Mouse Logo
49 people viewed this question
Top NexxTech Computers & Internet Experts
Alun Cox
Joe Goldman
Joe Goldman
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
