Question about Kenmore 47153 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Kenmore Elite 790.46623502 Stainless Steel Dual Fuel - Replace Glass Top
I need to replace the glass top of my range: Kenmore Elite Model No: 780.46623502. This is a dual fuel and the cook top is gas. Thus the replacement is only for the glass top (part no: 318223722).
The question is: Is there any adhesives or gaskets required for this replacement? The glass seems to be sitting on the top (no frame around - this is a slide in range) and there is only a gasket/seal in the front. I assume that I need to take out the burner caps, the burners and the seals. Is there any other part that needs to be replaced as part of this exercise? Do I need any adhesive?
Finally, is there any tip of how you seal the gap (if it is sealable) between the glass top and the countertop underneath as this is always a place of dirt trying to get in.
Many thanks in advance
5 Suggested Answers
  • 29 Answers
SOURCE: My Kenmore glass top range,
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
Posted on Jan 29, 2009
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
  • 18 Answers
SOURCE: replace glass on front of oven
Hi You need a high temperature silicone adhesive designed for this purpose. There are a number of companies that make a suitable glue. There is also a company, http://ovendoorglue.co.uk that make a small kit specifically for the purpose of fixing your oven door. Do not use normal adhesive, as the correct adhesive not only is heat proof to 300 degrees centigrade, but also remains flexible when cured. This ensures that as the oven heats up, and the metal and glass expand, the flexibility in the glue prevents stress in the glass. Dow Corning make a glue that can be used, but be aware that it is red, and so may show. Other glues are black. Indeed the black glues tend to be slightly thicker on application and dry quicker.
Posted on Jun 08, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore elite dual fuel range - all burners'
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 07, 2010
My kenmore elite washer keeps giving me the LE error
Kenmore elite 700 series triple action technology glass top load 5.3 cu ft.washer glass lid is shattered..can I replace the glass only or do I have to replace the whole lid top?
Mar 16, 2017 | Kenmore Washing Machines
Kenmore Elite range model c970-635131 stainless, oven stopped working
You have short in the wiring; you better call a professional repairman.
Feb 14, 2015 | Kenmore Kitchen Ranges
How do I replace glass top on the stove model number FEF336ECE frigidaire?
The following link explains step-by-step how to replace a glass cooktop on a kitchen range:
http://www.fixya.com/support/r4249512-replacing_glass_cook_top
If you have questions about any of these procedures, please post back and let me know. I hope this information is helpful to you.
Jun 18, 2010 | Frigidare FEF336EC Stainless Steel...
Clean oven burner
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Feb 23, 2010 | Kenmore 79013 Stainless Steel Gas Kitchen...
Need new stainless steel top.
  • Firstly clean with DeBruce Polish to clarify area.
  • you may have to "re-grain" those finely scratched areas.
  • Blend or "scratch out" the misdirection scratch's with new "controlled" scratching, useing a 3M scotch brite #7447 you get at auto parts store (Nappa). Use medium very firm pressure.
  • -Re-clean with DeBruce Polish. Touch ups are now a breeze
  • DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. NO NEED TO REPLACE. We buy DeBruce at debrucepolish.com.
    Feb 16, 2010 | Tappan TGF657 Gas Kitchen Range
    I need to replace the stainless skin on my freeze
    You will most likely need new drawer unit Warner's Stellian in Saint Paul, MN can help. For cleaning DeBruce Polish is the best.
    Jan 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Broken pryrex glass ontop of stove how and were do i replace this part
    you have to order the top through an appliance shop...they are about 300.00 to replace
    Jan 04, 2009 | Kenmore 46123 Stainless Steel Electric...
    47153 Cleaning Glass Door
    stains on inside of outer most glass???. the instruction manual should explain oven door removal procedure. after taking off door a few screws around perimeter of door will relase the outer door skin/ glass. giving you acess to clean it. I wouldn't reccomend digging down much further htat that though, too many screws and panels and nonsense.
    Mar 05, 2008 | Kenmore 47153 Stainless Steel Dual Fuel...
    Kenmore 47153 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
    243 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Sal De
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
