Question about Hoover Dishwashers
Machine not emptying. I have checked & cleaned filter. Holding down the function key nothing happens
An engineer had to come out and found some class in the pump which he removed and the machine funtioned again.
Posted on Aug 18, 2008
Indesit WDG1295W. Why doesn't it drain?
The pump and connecting lines could be choked with debris the filter didn't catch.
Dec 26, 2015 | Washing Machines
Shuts down and gives me failure E 1 on the card and will not start
E1 = The air filters need cleaning (after 720 Hours use)
It will shut down until you clean the filters & reset the E1 alarm code.
To do this you need to:
Pull the Air Con appliance lead out of the power outlet in the wall.
Remove & Clean the air filters & then put the cleaned filters back in machine
Before plugging back in you Push & Hold the Power button on the Unit
THEN while holding the power button you PLUG the lead back into the wall.
Keep Holding the power button until you hear the unit emit a beep (hold for approx 5 secs)
Then disconnect the power supply lead again.
Then Plug it back in again & turn on
It should be cleared & working well.
Good luck
Aug 10, 2013 | Sharp AF-S120FX Air Conditioner
My computer laptop model is Toshiba satellite P750. The FN key doesn't work. Nothing happen when i touch it.
The "Fn" key is a function key, it works with the top row of F1 to F12 keys.
By pressing and holding down the "Fn" key, then pressing one of the top
row "F" keys,
I'v provided a link for you to go to for the full list of "F" functions and what they
do for you as well as how to operate them on your Toshiba Laptop.
http://www.ehow.com/list_5941452_laptop-keyboard-functions.html
Aug 27, 2011 | Computers & Internet
I have connected my VGA lead into my laptop and Technika tv and nothing seems to be happening please could you help me
Every laptop comes with a key that shifts video. Look for a key with a box(in the function key line). Now holding down the Fn key, tap the other key until you get the display.
Apr 08, 2010 | HP Compaq 6720s Notebook
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
How Do I Change The Screen Resoluttion to 1280 x 1024?
you need to hook up a different monitor then go to the resolution properties and set it for 1280 1024
Oct 19, 2009 | Samsung SyncMaster 193V 19" Flat Panel LCD...
MY Maytag Washer SAV3710AWW STOPS AND WON'T DRAIN. WE HAVE TO MANUALLY DO IT. COULD THIS BE THE TIMER
No it is a fault with the pump if it does not empty the water the machine will sit there forever
Take out the lint filter and check that there is nothing holding the pump impeller back , use a skewer to check that the impeller will turn freely
If that is clear then take the drain hose out of the drain clean the end and give a good blow into it , if you hear bubbles inside the machine fine if not then you have an item of clothing down the pipe from the drum to the pump.
If you hear bubbles and the impeller is free then the pump may have failed , it is very unlikely that it is the timer
Jul 09, 2009 | Maytag Washing Machines
Washing machine makes a loud rattling sound
Hi.k.
Even though you have cleaned filter, there could still be something in the pump, you need to remove the pump and check there is nothing in it.
Hope this helps.
Good luck.
Please leave feedback
Nov 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Starts then stops and won't re-start
Plug off the wall first. Check your outlet filters, clean out. It is located right in front bottom right of machine. Push one side of the small door. The machine will not spin if the filter is blocked. Refit carefully. If you have manual, check for filter cleaning. While you are at it check your pump area too. Position machine switch to "off" position. Re-start........
Oct 14, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dishwashers Logo
56 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
