Question about Technics Audio Players & Recorders
Old Quadraflex 777 receiver problem
This is an older receiver...one with tubes and knobs.
the right channel to the speaker keeps buzzing and blurting music in stops and starts, at a loader volume then the other. i checked the wires, the speaker is fine...what is it?
a tube?
what do i check
and how do i clean the 'pots' on the volume knob?
this is a question for an older tech...i imagine.
  • 81 Answers
SOURCE: UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Posted on Dec 15, 2006
  • 163 Answers
SOURCE: Channel Problem
It could be a bad balance control potentiometer or just broken/cold soldering joints due to the age. Bring it in a repair shop. Thanks. ebcelectronics
Posted on Apr 09, 2009
Testimonial: "If I didn't say it before, thank you. You were right on the mark with the soldering joints. I took it to an electronics shop and they fixed the problem well. It wasn't cheap to say the least."
Samyfam
  • 379 Answers
SOURCE: why do the volume numbers on old receivers start
This type of calibartion is known as a logarithmic scale.
The numbers refer to decibels below the maximum output of the amplifier section of the reciever, or decibels of attenuation (making smaller/quieter).
Without going through logarithim theorey, the logarithim (base 10) of 1 is 0. So if 1 is the maximum output of the amp, as you turn the knob down from maximum you are adding more and more attentuation to the output (relative to maximum) and so the loudness of what you hear goes down, even though the number on the scale is going up !
Most peolpe associate decibels with sound levels, but anything can be measured in decibels, so long as there is soemthing to reference it against.
Posted on Nov 04, 2009
  • 382 Answers
SOURCE: RF channel is messed u
Problem is it is a common problem. I have one with the same thing, it appears as though HK discoed the line for a reason and sold them all at half price in Costco.
Posted on Jan 15, 2010
linswad
  • 258 Answers
SOURCE: Right speaker is distorted with low volume, left
There is something wrong with the right channel amplifier, you need to get this equipment serviced.
Posted on Mar 26, 2010
Sansui AU-D33 Lh speaker channel not working.
As the channels are identical you can use the good channel has a guide to the bad one. First thing is to look around see if anything does not look the same as the right channel.
If nothing obvious stands out, with the power on, using an insulated screwdriver touch the two channels one at a time. Keep away from the power supply and anything that is common to both channels. The channel will buzz once touched. Depending which points you touch them. The right channel will tell you if it should buzz at that point. Work backwards from the speaker outputs if you can. If you hear a buzz on the left channel then it is working at that point, if it produces the same sound on the right.
Using this method you should track down the part that has gone.
Dec 11, 2015 | Audio Players & Recorders
Right front channal buzzes
Only the one channel buzzes? Did you check the cable of the speaker is it properly rolled?
Feb 17, 2014 | Onkyo TX-DS575 Receiver
Only get sound out of right side both a and b
Good day sir, Hi, your Philips receiver trouble can be any of the ff:
  1. your receiver left fuse is blown, check if it has a user fuse at the back. or
  2. your main IC amplifier for the left channel is bad. you need to replace that IC, but check first the wiring of the speakers.
  3. Check your receiver left speakers if it is producing a soft hum, to do this turn down the right channel, or adjusting the balance knob to the left, or simply remove the speaker connection of the right channel. place your ears on the left speaker as you adjust the volume up and down, do you hear a soft hum that goes up and down also? If yes the problem is on the source section before main amplification, usually the pre-amplifier stage, If you hear no hum at all. problem with the main left amplifier. The main amplifier is usually a single IC for both left and right channel, OR one IC amplifier for the left and one for the right, in both cases, replace the bad IC.
Jan 21, 2010 | Philips Audio Players & Recorders
Yamaha RX-550 receiver. Presently, no sound on left speaker channel. Previously, no sound on right speaker channel could be cleared by rotating the Input nob.
were you able to solve this one ? I have the same problem with mine. The only way to clear the lack of sound in one of the speakers is to rotate the input knob !!
Oct 18, 2009 | Yamaha Audio Players & Recorders
Channel Problem
Apr 06, 2009 | Audio Players & Recorders
Right side speaker barely works
Likely the control is old and dirty.  It is known as a rheostat on older units and often a little contact cleaner on it will work.  A simple thing to try that might work is to rotate the knob back and forth, left to right, each time going to full stop.  do this several, several times.  See if this makes things better.  Of course, the assumption I am making is that the right speaker is operating normally.  If you switch out the left speaker for the right, and the problem persists, on the same side, it is the receiver.  If the problem now appears on the left side, it is a speaker issue and not the receiver.  Good luck and let us know how it goes.
Jan 02, 2009 | Audio Players & Recorders
Yamaha rx 596 problem
ya bad ch unless u know how to work in ther best bet to buy new harmen kardon 7.1 or kenwood 7.1 thx on ebay 250 sound amizing clean warm like tube
Jan 20, 2008 | Audio Players & Recorders
SR4300 Centre Channel
Hi...
Try another GOOD speaker on your centre channel.
If the buzz ....buzzes off, it's a bad speaker.
If not , It's in the power amp section on the unit.
Sep 14, 2007 | Marantz SR-4300 Receiver
238 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
