Question about Brinkmann 810-8410-S Stainless Steel Propane Grill
Brinkman gas grill won't start. Don't hear clicking sound. Hooked up new gas tank, but no success
    Brigadier General:
  • 4,736 Answers
Victor, are you sure you're getting gas to the burners after installing the new tank? You can try match lighting them to make sure. But, I suspect, that it's the installation of the new tank, that's causing the problem.
To test my theory, tune the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Ope the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, try lighting the burner that's farthest from the tank first and turn it to high. Did the burner light and does the flame height look correct? If so, light the remaining 3 main burners the same way. Did those burners light and the flame heights looks correct? If, so you solved the problem. Remember to always turn the tank valve ON VERY, VERY SLOWLY.
Hope this helped you solve the problem. Happy Grilling.
Posted on Jun 01, 2011
  • Charles Slayton
    Charles Slayton May 06, 2014
    if there is no clicking that means the striker isnt work so rich is a total idiot thinking its the gas tank
After replacing LP tank, will not start - I don't even hear the gas.
turn off gas on tank open gas burners , turn off gas burners turn on tanl slowly should work now .
Aug 23, 2012 | Weber Genesis Silver B Grill
Gas grill was washed now it won't light
Regulator. Tanks were non burped... Regulator stuck. Turn off tank slow. disconnect. Turn burners on. Tap the regulator with a piece of metal. Turn burners off. Connect tank. Since it was washed out electric starter dont work. Turn burners on. Then you will hear it. Gas. Take lighter and start. Big startup. The hair on your hand burned off wash your hands. Then get the meats! Easy as Cake
Jul 13, 2012 | Grilling
No sound of gas
Tyrn off tank open conrtol knobs to burners , turn off burners turn tank on slowly see if gas comes out now , if not check burners are not blocked or injectors are not blocked
Jul 04, 2012 | Grilling
I have a Brinkman pro series 6330. I just went and had my tank filled and when I hooked it up and turned the burner on to light it, there was no gas getting to the burners. I tried some of the tricks I...
It's a regulator problem, but one that is usually resolvable by doing the following.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly after it is installed or you will be back to square one, again.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Aug 03, 2011 | Brinkmann ProSeries 810-6330-W Grill
When I try to light my brand new Q300, it won't ignite. I can hear that the tank is on and gas is being sent to the grill. However, it doesn't light. When I shut the grill off and the gas tank...
What you have is delayed ignition. It's being caused by the gas regulator. It is solvable, though.
Once the valve is fully open, light 1 burner and turn it to HIGH. Did the burner light and does th eflame height look correct? If so, light the remaining burner the identical same way. Now, to both flame heights look correct? If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly. And always light the burners with the Lid/Hood Open.
If the above did not solve the problem, you will need to replace the Hose/Regulator Assembly. Since your grill is brand new, the Hose/Regulator Assembly will be covered under Warranty. Have your Proof of Purchase handy and call Weber 1-800-446-1071. Also, if you haven't done so already, register your grill before calling http://help.weber.com/register/ even if you don't need a new Hose/Regulator Assembly.
Hope this helped you troubleshoot & solve the problem.
Jul 06, 2011 | Weber Q300 Grill
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
Periodicly I won'y be able to get the grill temp to over 200 degrees. sometimes it is ok and can reach as high as 500 degrees other times it will just not generate enough heat to grill.This is a five...
zonfish - if you're tuning the gas tank off at each use, as you should. The problem lies in your grill's gas regulator, but it also is not a big deal and is easily solved.
Whenever, you open the tank valve, do it VERY, VERY, SLOWLY (Slow Motion, slow), until it is fully open. Then light the burners.
What happens is this, LP Gas Grill Tanks are now equipped with an Overfill Protection Device ("OPD"). And often time, when you turn the valve on like you would normally do, the OPD Valve sends a hot load of gas to your grill's regulator and partially locks it up or locks up entirely. Therefore, the burners are not getting enough gas to heat the unit up to 500 degrees. Opening the valve very, very, slowly, overcomes this problem.
I hope this helped you and Happy Grilling.
Jun 20, 2011 | Brinkmann 810-2300-B Grill
Just purchased new Brinkman 5 burner Pro series. Worked fine when I tested it but now the main burner is the only one that will ignite and it won't stay on. The side burner works great.
First, check the gas line hose from the tank to the grill. Look for kinks or twisting that would restrict the flow of gas to the burners. If you find any, turn the gas tank valve OFF, disconnect the hose from the tank and straighten the hose, before reconnecting it to the tank. Then open the gas valve Very, Very Slowly, until it's fully open.
If you didn't find any kinks or twist, do the following:
1. Turn the gas tank valve OFF, Disconnect the hose from the tank and wait 5 minutes.
2. Turn on any pair of burners to High for io minute and then turn them OFF.
3. After 5 minutes has elapsed, reconnect the hose to the tank.
4. Open the tank valve VERY, VERY, SLOWLY (Slow motion, slow) until it's fully open.
5. Light the burner farthest from the tank first and turn it to HIGH. Does the flame height look
correct? If so, light the remaining burners the same way. Do all the flame heights look correct?
If so, you solved the problem!
Hope this helped you . Please let me know and Happy Grilling.
Jun 19, 2011 | Brinkmann ProSeries 810-6330-W Grill
I just got a new gas tank and the heat won't turn on
Do you hear gas coming from the grill when you open the valve? If all the valves are open and you don't hear anything coming out, you may have a bad gas tank. Take the tank back to the store and tell them there is something wrong with the valve and you want to exchange it for a new one. They should do this free of charge.
May 31, 2011 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Last summer closed up grill had no problems..today not working
unhook the tank and hook it up again being sure that the regulator is right side u p.
these new grills have a safety valve that often partially closes and causes problems.
Apr 27, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Brinkmann 810-8410-S Stainless Steel Propane Grill Logo
1,109 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
