Question about HP Color LaserJet 2600n Printer
Hp color laserjet 2600 megnta not printing
Have problem of 2600 printer that not printing megenta.printing in yellow only ..please help me to solve the problem.thanku
  • Anonymous Jun 23, 2009
    thanks alot ...my printer working now
Thanks alot u solutions.iam very happy for giving me this knowledge.faisal
Posted on Aug 26, 2008
  • 300 Answers
It's normally caused by dirty scanner mirrors, the machine will need to be dissembled, the laser scanner unit removed, taken apart and the mirrors cleaned. Unfortunately it is quite fiddly getting the scanner unit out, but this is a very common problem for the HP colour laserjet 2600's and the problem normally always start with the magenta first.
Posted on Aug 25, 2008
SOURCE:
Only printing Yellow
Sir/Madam
Please See The Vedio On Youtube
By This Time i Fixed My Problem,
HP 2500 color only prints yellow
or
Follow Us On
HP Printer Support
Jan 08, 2014 | HP LaserJet 2550n Printer
' Printing Weak Magenta CM1015
You can increase the dencity of each catridge, before that set as difault setting, do color calibration, check if not satisfied inrease the dencity of megenta in menu#system settings#quality#catridge#megenta#+1 or +2 or +3 choose desired quality,even you are not satisfied clean the laser scanner assm..
Sep 27, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
HP LaserJet 1600 Printer Logo Problem with the HP LaserJet 1600 Printer My hp color laserjet 1600 ''incorrect yellow'' @yahoo.com
LOCAL PC PRINTING GET QUICK BUT DOMAIN USER NOT GET PRINT MANUALY PRINTER SPOOLER RESTART IT WORKING HOW TO SOLVE
May 14, 2011 | HP LaserJet 1600 Printer
Hi i have 51.2m error of hp-color laser jet.5500
Dear friend,
There is a problem with the megenta colour scanner.Try to clen it.If it won't help you have to replace that megenta scanner.
Mar 09, 2011 | HP LaserJet 5550 Printer
Will not print blue? HP 2600
SPACILLY FOR HP PRINTERS DONT USE THE REFIL CART
this problem due to refill cart replace with new one ur problem will be resolved
Jul 01, 2010 | HP Color LaserJet 2600n Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Xp driverd for HP 2600 color
On the HP website for driver downloads we used the last set of drivers listed (script) that solved the problem of no color and 11x17 sheet.
Oct 22, 2009 | HP LaserJet 1000 Printer
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
HP 2600 Laser Printer
Clean the paper path. See the HP Toolbox online Help.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00316826
Jan 16, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
375 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
