Question about Car Audio & Video
2005/2006 ford mondeo sony 6cd audio player
How do i connect my amp to my sony cd player as there are not any output jack plugs coming out the back of the system
You can use what is called a line level converter, which taps into your speakers to convert the signal to rca cables. that is about all i can think of since i don't know the model number of the cd player
Posted on Aug 18, 2008
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
Unable to play and eject and cd's from sony 6cd in my ford mondeo Mar 2007 model
some mechanical problem inside your stereo cd unit that maybe broken parts, circuits, jam or foreign object
Feb 02, 2011 | Sony Car Audio & Video
How do i connect a dual karaoke cd player with seperate audio outputs to an amp with single inputs?
you can get a connector from maplins just take the lead that you want to connect to the amp without knowing more i think your k player will be small phonos and the amp input will be standard jack so if so ask for two phonos into standard jack plug cost about 1.99
Mar 07, 2010 | Audio Players & Recorders
2004 Ford Mondeo Sony 6cd radio manual
Ford 6006CD 6 change. I have the code! how do enter it?
Dec 11, 2009 | Car Audio & Video
Is sony cdx gt24 has an ability to connect in an amplifier? its has an auxiliary in front and its mp3 player... Max. output 4 x 45W...
From memory I believe you can, it should have the 2 connecting jacks and speaker jacks in the back, let me know how you go. Good luck
Nov 20, 2009 | Sony Xplod AM/FM CD Player w/ MP3 Playback...
Ford Mondeo 2002 6CD auto changer. Error message E 3
According to the Ford Handbook Error Message E3 is "Mechanical Error " and their suggestion is "Install a new Audio Unit "....which is not very helpful
There`s not much that can be done as a D-I-Y solution with these CD Units apart from cleaning the laser lens with a cleaning disk+solution (from your local audio Store or Ebay etc)....or a full reboot ...by disconnecting the unit from the battery for 20 minutes , replacing it and hoping that it will have reset itself.
Make sure you have the correct radio code before attempting this disconnection procedure ( If not, just post the Serial Number (found on a label on the casing) and someone will calculate the correct code.
Sep 01, 2009 | Car Audio & Video
No sound to the subs
Possible solution: Check to make sure your ground connection is connected to metal that is NOT covered in paint. This is not a solid connection and can ruin your amp over time. Simply scrap away the paint and re-connect. This was a problem i ran into recently.
Jul 27, 2009 | Sony XPlod CD Player w/MP3 Playback...
How to connect eq to audio amp
To EQ all audio sources you'll need to have a receiver/amp with either a tape monitor loop or a pre amp-in/main-out loop. Look for a button on the front labelled 'Tape Mon' or ins and outs on the back labelled pre amp-out/main-in. If you have these you can connect the outs from the amp to the ins on your EQ and then EQ outs go back into the amps ins. If you have a tape deck as well, the EQ's 'tape mon' jacks replace the ones it takes up on the amp, so just plug your tape deck in here.
Just remember that whether you have a tape deck or not, if you hang an EQ off the 'tape mon' loop you'll have to engage the 'tape mon' button/switch for playback with EQ.
If your amp doesn't have these loops you can still use EQ but you may be restriced to one audio component source. So say you wanted to EQ the playback from your CD player, you'd just connect the CD players output into the EQs input, then connect the EQ's output into the amplifiers input (for CD player). Then everything you play through the CD player will be EQ'd.
Jan 01, 2008 | Audio Players & Recorders
Car Audio & Video Logo
615 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
