Question about GE Dishwashers
Dish Washer, Model GLDL560N1055, S/NAR 808556B. Dishes and other items are not drying. They are still wet not damp. Brochure says try "Hot Start,Hot Wash or Added Heat options. Do I use Hot Start and Hot Wash at same time? Why must I use options rather then the normal control? I purchased 7 addtional GE appliances, recently, and Dish Washer only problem.
5 Suggested Answers
  • 86 Answers
SOURCE: Wet dishes; steam does not escape
Hi, Most dishwashers do not have steam vents! there are several reasons for poor drying in a d/washer! The first one is to see that you have rinse aid in the machine as this aids drying! Next if you have rinse aid then is it being put into the machine when it needs it? Also you must bear in mind that the dishwasher need to heat on the last rinse to create the heat to dry the items which use the steam to dry them. Check the rinse aid first and see how you get on....
Let me know.......
Posted on Dec 30, 2008
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
  • 48 Answers
SOURCE: foul odor on dishes and in dishwasher after cycle
It is very likely that your dishwasher is growing mold, in this condition. If it is causing your dishes the same issue, it may be wisest to obtain a dishwasher cleanser(Several detergent manufacturers now sell dishwasher cleaning items), which will hopefully kill off any mold colonies growing in your dishwasher's blades, and in your drain cap.
Posted on Apr 23, 2010
SOURCE: GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Posted on Dec 30, 2010
The automatic delicate drying cycle does not dry
The delicate cycle is for damp, not wet delicate items. It is more warm air then hot and will not dry wet items forsay. If you have delicate items that need more drying try putting them inside a pillow case and tying the end closed long with a higher setting. Works great with stuffed toys too
Feb 24, 2010 | Whirlpool LTE5243D Top Load Stacked...
DISHWASHER
if your unit has fuses. check it out first. a blown out heater element might be the cause of that.
May 20, 2008 | Dishwashers
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Sep 16, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Bosch dishwasher SGS55M2 leaves dishes wet
Are you using drying agent?If not you have to use it in bosch dishwashers.When the cycle is completed is it hot,steam rolls out.if not you have a heater problem or thermostat problem.
If you need more info please ask
Feb 05, 2009 | Audiovox Bosch 718 World Cellular Phone
Dishes not dry enough & leak of water at sink vent device
HEATED DRY.Turns the drying heater on for fast drying.
ENERGY SAVER (no heat boost). Turns the drying heater off to save energy. Dishes will dry naturally over a longer period such as overnight. lf you need your dishes sooner, open the dishwasher door after the cycle is complete to reduce the natural drying time. Use of this option reduces the electrical energy used by this model approximately 7%. A rinse agent makes water flow off dishes quicker than usual. This lessens water spotting and makes drying faster, too.
Make sure inlet water temperature is correct.(SeePage6.)
Unload the bottom rack first.Water from dishes in the top rack may be spilling in to the
bottom rack.
Check for improper loading.Dishes shouldn’t nest together. Avoid overloading. Check the rinse agent dispenser to see that it’s not empty.
Inlet temperature....Good Dish washing starts with hot water, To get dishes clean and dry,you will need hot water.To help you get
water of the proper temperature, your dish washer automatically heats the water in the wash cycle. For good washing and drying , the entering water must be at least 120°E To prevent dish damage,
inlet water should not exceed 150”F. How to test water temperature: Check the water temperature inside your dishwasher with a candy or meat thermometer. Let the dishwasher run through
one fill and pump out cycle, then let the dishwasher fill with water
the second time. When you hear the water stop filling, unlatch the door and slowly open it. Measure the temperature of the water in the bottom of the tub this way: Remove the silverware basket and
place a candy or meat thermometer in the water towards the middle of the tub. If the temperature is less than 120”F,you will not get good washing results. Higher water temperature is needed to dissolve grease and activate powder detergents. If the unit is a long way from the DW you may need to let the water run in the sink until hot before starting the DW....or if is a cold day and water has not been used in a while the pipes could be cold....also if you have just used the hot water ( washer, shower...etc) give it time to recover first before using DW....All of the above mentioned material is straight out of the Users guide...but you may have an element that is going out also...so check the temp of your water and open it during the drying cycle to see if it is hot or at least warm inside...if not your element may need to be replaced...
I hope this helps...have a great day & good luck...please rate my effort.... the Fang.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Let me know.......
Aug 01, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Model LD1403W1
Are you using a rinse aid like Jet Dry??  All dishwasher manufacturers now require that you use rinse aid for drying dishes at the end of the cycle.
Dec 29, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishes stay wet after cycle
No drain hose routing has nothing to do with drying performance. The biggest thing that affects drying performance is water temp. Modern dishwashers use such a small amount of water is usually never gets very hot before the dishwasher has reached its full level. You can try to select hi temp wash and that should help. Also make sure that heat dry is selected. Also you really to purchase jet dry and install in dispenser. This will improve drying as well.
Dec 01, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwashers Logo
53 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
