Question about Microsoft Xbox 360 Console
Connection failed we changed cable providers and now the it says the test fails and everything is connected the same way
    Problem Solver:
  • 17 Answers
Is the connection wireless or wired? wired it should work fine but if it is wireless you may need to re set up your router and or the wireless settings in your network settings.
Posted on Aug 28, 2008
I have a 1989 560sec everything on but starter wont turn over any suggestions?
If everything else works { lights, radio etc } then check the connection at your starter.
Aug 17, 2014 | Cars & Trucks
Powers up, fans work, but nothing happens. Can not even get into the Bios. red light on between the power connection and the IDE connections?
I will assume that you have everything connected properly and are using the integrated video on the motherboard (not a separate video card installed in a slot). Usually the red light on the motherboard (mobo) is a power-on light, meaning that it is plugged in to a power socket.
First try to clear your CMOS settings:
Unplug the power cord and remove the CMOS battery for 15 minutes. If your mobo has a BIOS reset jumper, move it to the Clear position and back to normal. If you aren't sure what these things are, it will be in your manual that came with the mobo. Now re-connect everything and try again. Make sure that you are plugging the video cable into the proper socket and your monitor is working. If you can use a DVI cable on that board, try that connector. Make sure your monitor is working.
>Visually check for failed capacitors; caps that have ruptured are increasingly common and can stop booting.
>Your CPU may have failed; this is a typical situation then the chip fails. Everything works except there is no video on the monitor.
For more detailed testing and information, go HERE.
Oct 10, 2013 | QDI Group QDI Advance 6T Motherboard
When I use the wi-fi connection with the LAN cable provided and run the connection test, all of the tests are successful except for the Viera connection. It is saying the connection failed 006. How do I...
Viera has a set-top box in the TV and the lan wifi router can be connected to cable plant for internet. TV can also send out programs on the set-top box to other wifi receivers. Error code 006 is server failed, Panasonic had a fix on jan11, 2012.
Feb 11, 2012 | Computers & Internet
It keeps saying to check cable connection - PXE-MOF: EXITING INTEL PXE ROM
That error message appears when the northbridge can't connect with the hard disk thru the southbridge - this happens because either the hard disk has completely died, the cable that connects it to the motherboard has failed (or got yanked out) or the southbridge has died.
So some testing will have to be done: open the bottom of the laptop, take out the disk and reatach the cable; if that fails then get a second disk and see if it gets detected, if this also fails then connect a simple dvd writer in place of the hard disk: if it fails even now then the southbridge has failed, the motherboard will have to be replaced.
Aug 16, 2011 | Toshiba Computers & Internet
I have a samsung tv , and im setting up my INTERNET@TV , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Feb 28, 2011 | Televison & Video
Everything works well on my wireless linksys e2000 router my itouch, my computer except my samsung wireless lan adapter wis09abgn cant seem to connect to the internet on my Tv i plugged it in the usb slot...
IT looks like it might not be accepting the type of security on the router..try changing the security typa it might work.
(P.S. YOu might need to re-connect all the wireless computers to the new network once you change the security.)
Hope this helped.
Feb 13, 2011 | Computers & Internet
During my linksys install, the software validates my connection and fails everytime. I do not have an adapter on the computer I am installing the software on. This PC has direct cable connection to...
You need to have the router connected directly to the computer to do this setup. If you are directly connected to the internet you cannot communicate with the router and most everything will fail. Remember to set wireless security on the router, give a ssytem name and consider setting channels to 11 or so to not compete with wireless home phones.
Oct 03, 2010 | Linksys Computers & Internet
Can't get network connection to work.
Are you trying to connect to the Internet using a wireless router or vai a network cable?
Have you got an Internet Service Provider and does your computer have trouble connecting to the Internet?
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
Thinkpad x60 reboot fails. Error message: Media test failure
plz check the hard disk data cable(cable which is connected to motherboard), if changing the cable do not solve the problem your hard disk may be corrupt
Mar 01, 2009 | IBM ThinkPad X60 Tablet PC
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
