Just purchased an LG W2052TQ LCD monitor, it worked fine until I installed the forte Manager from the CD, now it just reboots and then shuts down before it is fully booted. I am unable to get into the computer to delete the file that I loaded.
    Sergeant:
  • 395 Answers
Press F8 a lot of times before it boots and choose Safe Mode or VGA mode boot, then uninstall the driver that you just installed or use System Restore to go back to a point before you made the change
Posted on Aug 17, 2008
Analog out of range...screen blank tried booting with f8 but then what?
You will have then to open Device Manager, remove the display adapter driver, then reboot the computer.
Once Windows starts up again after the reboot, it will detect there was a hardware change due to removal of display adapter driver, & will ask for the driver's CD to install it from. Once this is done, everything will be back to normal.
Aug 31, 2011 | LG 22" FLATRON LCD Monitor
How do I reset my flatron w2052tq monitor to factory settings? . I shipped my monitor to my new home and now I can't get my monitor and printer to agree on a color--I use a ColorMunki to calibrate,...
For the LG w2052tq, you can do a reset to factory settings through the OSD menu. Press Menu then go down to Setup. Press Auto/Set and go down to Factory Reset. Press Auto/Set and confirm the action. Then press Menu twice if needed to exist the menus.
Alternatively, press the Up and Down arrows together.
Remember that you can only adjust the white balance of the monitor when the incoming signal is Analog. Documentation for the monitor is available here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=W2052TQ-TF&matchedModelCode=1000004018&searchEngineModelCode=W2052TQ&initialTab=documents&targetPage=support-product-profile .
I hope this helps.
Jun 24, 2011 | Computers & Internet
Cold solder joint, or sometging loose inside. I need to disassemble the LG W2052TQ. How do I open it up without destroying it?
I use thin flat blade screw driver to separate the fron bezel from the back cover, starting at the bottom edge and work your way around. Lay the montior face down on soft surface when you almost have the cover loose, then snap it up to get the back completely off, just watch out for any cable and board assembly attached to the front bezel.
I could not find free service manual for you to lok at.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 27, 2011 | LG W2052TQ Monitor
How to install driver for lg lcd w1932. in cd came with monitor not have exe file and download from website too. in device manager monitor in status plug and play and not show name LG w1952 how to add...
well your monitor if connected with your graphics card wuld run on its drivers fine, the cd is just for the case if it does not gets detected. so u neednt worri bout the drivers and just njoy.
need ne help still, let me know
Nov 01, 2009 | Computers & Internet
ForteManager problem (LG monitor software)
I uninstalled the Forte Manager through the control panel as I was having recognition problems with my W2552.
It has solved the problem, and I have had no problems since!
Sep 24, 2009 | LG W2353V-PF 23' LCD Monitor
Dell Desktop DX270 doesn't work with LG w2052TQ monitor...
A Dell Optiplex GX270 can have either on on-board VGA integrated graphics controller or an expansion graphics controller. If an expansion card is installed, the onboard graphics is disabled.
So first, ensure that the VGA cable is connected to the correct graphics connection (If there is an expansion slot with a video connector, ten you must use that connection)
If connected to the correct port on the system, next ensure that the input select for the monitor is either set to autoselect or ANALOG
Last ensure that the display resolution of the graphics adapter will support the new monitor.
Feb 05, 2009 | Dell OptiPlex GX270 PC Desktop
Digital shut down
Try making sure the video card's Display Settings have the Screen Resolution set to a level that are compatible with your LCD monitor. Try starting at 800x600, applying the settings and testing them, and moving up slowly until it doesn't work anymore, then stay at that same level.
Jun 11, 2008 | Gateway FPD2275W LCD Monitor
Now only PC starts booting up but then stops dead, blank screen
Try pushing F8 on startup, this will get you into the safe mode menu. From there select VGA mode. This will start your computer with the most basic set of video drivers.
You should be able to get one of the two monitors working this way.
Jan 03, 2008 | LG L1915S 19" LCD Monitor
Analog Out Of range (LG Flatron L1750T)
some games need high resolution. Monitor resolution not supporting for this game.
Powersaver mode showing when the main PCB of the monitor failed. check this link to get the service center info
http://www.lgservice.com/
Nov 21, 2007 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
