Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Door will only close when held down
Got the Chamberlain Professional garage door opener model 41BD002-2 & have to hold down button to close it until it goes all the way down. Tried moving sensor with orange light & it still won't change. Any other suggestions? Reinstalled opener at a new location- was working perfect b4. Now that I have reinstalled the problem is:
when I push the opener it very briefly attempts to close and then stops and makes 4 to 5 clicking noises and then stops. If I hold down the button it will close smoothly until I let go of the button and then it opens all of the way again and makes the same 4 to 5 clicking noises. Even if I hold it down until it closes all the way it wont stay down - it opens back up.
  • doclamanna Sep 08, 2008
    I   have the same problem. exactly.
    Chamberlain1/2 hp residential opener
    Scholar:
  • 91 Answers
The problem is in the sensors at the bottom of the tracks. They both should have lights on them one orange, sending, and green, receiving. In almost all cases theres an indicator on each side to let you know that sensors are positively aligned. Check wiring.
The only other problem I have seen is if the opener has gotten damaged by a power surge or lightning. The safety sensor part of the computer board on the back can get damaged, and maybe a sensor or two but, everything else works ok.
Posted on Sep 02, 2008
    Sergeant:
    Champion:
  • 298 Answers
Sounds like the gear drive is getting worn.
also make sure the track are free of any debris.
Posted on Aug 17, 2008
My Chamberlain 41A5389-1B 1/2HP door opener will only close via the wall push button when it is held down until door is fully closed. Will not close with remote, when using the remote it will start to...
Have you checked the tracks on both sides? If the door closes when you hold the wall button there may be an obstruction or a bad guide. This could exert enough resistance to make it stop and reverse. Holding the wall button allows it to keep going past the problem.
Apr 28, 2017 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener opens with remote but will not close with remote. will open with wall button but button must be held down until door touches floor to close
Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Nov 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
it works but it is annoying: you will have to hold down the button on wired wall unit. hold it until the door closes. also if you have the keypad outside it also works the same way, type code and hold the enter button
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman garage door opener
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Jun 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
if you obstruct the photo eye does the light flash ?
Jun 13, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
261 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
