Honeywell HZ-705.....HELP!!!! my grandmother gave me this heater and i have no idea how to work it. also, do i need to refill the oil? if so, what kind of oil? any help would be greatlt appreciated. please e-mail me at [email protected] with any instructions you may have to give. thank you, Matt Peterson Wilmington, N.C.
  • Anonymous Aug 18, 2008
    thanks
  • Anonymous Nov 04, 2008
    hgj,.ft
  • 4 Answers
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Aug 18, 2008
SOURCE:
I need instruction manual for HZ-705 oil heater lost manual when moving, can I dowload.
follow the link:
http://www.2shared.com/document/HyzOEjtx/oil-filled-heaters.html
Nov 07, 2011 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
I need an owners manual for my Honeywelll-kaz HZ-705
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can't find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Sep 23, 2010 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
I broke one of he plastic casters on my Honeywell HZ 705
Some full service hardware stores sell replacement casters, you'll just have to find one that will work. Good Luck!
Apr 25, 2009 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Instruction manual for hz705 honeywell oil heater
May I suggest contacting the manufacturer, Honeywell/Kaz direct at 800-332-1110.
Dec 24, 2008 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Help
I have searched it myself and can't find it online, May I suggest contacting the manufacturer, Honeywell/Kaz direct at 800-332-1110.
Dec 15, 2008 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Instruction Manual for HZ-705
HZ 709 This model# is the closet we'll are gonna get unless I can find my manual and get it scanned. Scroll down to page 4.These instructions will give you a basic idea how this heater works. Good Luck :-) http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
Jan 02, 2008 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Defective plug Honeywell HZ 680C
just change the plug - get it at a hardware store. if your cord is flat, the center conductor is earth ground, green screw. the ribbed conductor is the neutral (white) and the ribbed conductor is the hot (black)
Dec 06, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Honeywell kaz HZ-705 oil filled heater
i have the same problem. i do'nt know if i have to refill the oil; if so, what kind of oil?
Matt
please e-mail me = [email protected]
Nov 17, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Need users manual for a Kaz oil heater
I dug up my user's manual just the another night to address a problem I had. If you contact me and still need a copy of it I will scan it and email it to you. It is a good reference on how to run the heater but doesn't say much about troubleshooting problems. To learn about that you have to email Honeywell, which I did, and haven't received a response yet.
Nov 03, 2006 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Heating & Cooling Logo
641 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
