Question about Kitchen Ranges
Whirlpool double oven - AKZ161/AV After short electricity failure we are unable to reset the clock and use the bottom (main fan)oven. The display continues to show 'stop'. We have previously reset the time many times over past years.
  • chriseastgat Mar 25, 2009
    I have the same on this appliance usually if the bottom oven has been operating at over 200 degrees. I have managed to reset the clock in the past by turning the over switch off and on again after a day or so, but I can't get it to work this time.
  • 22 Answers
Sound like the ecltronic oven control has shorted out pretty expensive part to replace.
Posted on Aug 17, 2008
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
I have a whirlpool double oven, self cleaning. I do not know the model number right now. We woke up this morning, and not sure if there was a power failure in the house, but the oven display is out. The...
HI,
Sounds like you need a repair person to check out the power to your display (clock), If your clock has power but will not display you could need either the transformer (low voltage 12 volts) or a ERC (which is the clock). Lately I have noticed transformers have been on the rise in several of these models. Also the transformer is alot cheaper than the ERC. If you can test this, you will find the connection you need is on the board as you tip the control panel, you will find the light blue wire bottom right of the control board. If you have 12 volts to the clock there, your clock is bad, in not your transformer has failed.
If you have never done anything like this call someone to help you, Be safe with electricity!!!
I hope this helps
Jul 26, 2011 | Whirlpool GBD307PDS Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
I have a Whirlpool AKZ161/ix/03 double oven in which the bottom oven will no longer heat up to the required temp. I suggest it is the heating element. As a novice will I be able to change the element and...
If it is fan assisted, and the fan is working o/k, then the chances are it is the element.
This is usually located at the rear of the oven compartment behind a removeable cover.
Normally a straightforward repair
MAKE SURE POWER IS OFF !!!!
Please rate my solution.
Thankyou.
Jan 27, 2010 | Ovens
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Main oven does not heat up
When you turn the main oven on, does the oven fan switch on?
When you turn the main oven on does the cooling fan come on?
Does the dial illuminate when the oven is turned on?
Does the oven thermostat neon come on the the oven is switched on?
Have you had a power failure recently and have not set the clock?
Are you sure that the clock/timer is NOT set and in manual mode?
Dec 13, 2009 | Stoves 720EF Electric Double Oven
Main Oven Issue??
the clock need to be set to work the main oven
Dec 03, 2007 | Tecnik TKC8525 Double Oven
Oven fan keeps on clicking
There are two things that you can check. one is your circuit breaker itself and the other is the internal terminal block that the main wires feed into. the terminal block could have loose wires which will cuase an intermittant PF to appear on the oven, disconnect from power before checking. The voltage at the oven will have to be checked with a multimeter to verify the proper levels. Be sure to be extra careful around electrical connections while the oven is connected to power.
Mar 06, 2007 | Whirlpool RBD245PD Electric Double Oven
Kitchen Ranges Logo
341 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
