Question about Braun Syncro 7526 Electric Shaver
Braun 8995 clean and charge stand
The clean and charge stand charges but no longer cleans. It simply shows the blue light on indicating that the shaver is clean. Pushing down the blue clean button does nothing.
  • Anonymous Mar 31, 2009
    Charges but does not clean the electric shaver.
    Braun 8995 charges but does clean anymore. Blue light shows.
    Sniper:
  • 67 Answers
It sounds like it may be dead, i do know of this great site that sells Braun stuff check it out maybe it can help. http://stores.ilikenew.com/-strse-Braun/Categories.bok
Posted on Mar 17, 2011
I don't have a solution yet, but I have the same problem and I can tell you one thing: the problem is NOT in the base. I ordered a new replacement base, and the problem remains.
So it's in the shaver itself. I took apart the shaver and disconnected the shaver head from the batter and circuit board (as someone suggested elsewhere on this site), but that did not help either. It could be that I need to "reboot" the circuit board somehow, though I didn't see an easy or safe way of removing the rechargeable batteries. (Maybe I should just run the shaver batteries down to 0 and then recharge. Yeah, that's my next experiement. ;-)
Posted on Jan 08, 2010
  • TheMikado Jan 09, 2010
    UPDATE: Running the battery all the way out (until the little screen says "empty") appears to solve the problem. After I did that, I returned the shaver to the cleaning base, and the blue "clean" light lit up. Then I pressed the cleaning button, and the system began an "eco(nomical)" cleaning cycle.
    With any luck, the shaver will contain to be cleanable at regular intervals.
    Novelist:
  • 124 Answers
There were several design flaws with the first incarnation of the Braun shaver cleaning base, in the 7000 series. The 8000 series base solves quite a few of them and are supposed to be quite reliable. Sorry to hear that yours is failing... it's rather uncommon.
I looked into obtaining a replacement for my 7000 series shaver cleaning base, but found the cost prohibitive. On mine, the infamous clip failed and would no longer hold the shaver in place (I have to use rubber bands to hold it).
In essence, you don't really need this cleaner. The best thing is to just tap out the whisker debris after each shave, then every couple of weeks use a cleaning solution and brush on the cutter block. But if you really want a replacement, I suggest trying to locate a used 8000 shaver (you can go with the lowest model, not the 8595). You might be able to get one on the cheap, especially if the shaver is beat up. I recommend going that route.
Posted on May 23, 2009
I have the same issue with a 7526 clean 'n' charge base. I could hear the motor for the fluid circulating pump whirring away. The problem turns out to be the motor shaft corroded and broke at a point where a gear should press fit on to the shaft. Motor turns-gear doesn't-fluid doesn't circulate. sigh... I guess this isn't so much a solution as a likely explanation. i will be buying a new Clean 'n' Renew base.
Posted on Oct 04, 2008
    Problem Solver:
  • 37 Answers
Use your Warranty. Or you could simply buy another one and return the Lemon one with the reciept for the new one.
Posted on Aug 19, 2008
The cleaning unit on my braun series 3 (350 cc-4)shaver will not work although it will charge after buying a new charging lead? Any ideas?
These cleaning systems are prone to many problems. If the shaver will charge directly from the cord but not the stand, your stand is faulty. They are not repairable since parts are not available. A new stand can be found at shaveroutlet.com if needed
Braun Clean Charge Base 5783 Fits Types 5772 5774
May 07, 2017 | Braun Health & Beauty
Does the arcitec 1050cc come with a seperate charging stand as well as the jet clean device?
Originally, all Arcitec models came with a simple charging stand. That part is no longer available. If you need a simple charging method for your shaver, there is a charging/travel pod. It can be purchased at shaveroutlet.com at the link below
http://shaveroutlet.com/philips-norelco-arcitec-power-pod.html
Feb 12, 2015 | Philips Norelco arcitec 1050CC Electric...
Braun 8995 - YELLOW LIGHT STAYS ON!
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
Jan 06, 2013 | Braun 8995 Electric Shaver
9595 Charger won't charge while in stand
Your charging and cleaning stand is faulty. They are not repairable because parts are not available. You can purchase a new clean and charge stand at shaveroutlet.com
Braun Series 7 and Pulsonic Clean Charge Base
May 21, 2017 | Braun Shavers Male Pulsonic System 9595CC...
It will not hold a charge from the stand but will from the cord directly. it also does not clean properly model syncro 7526
The stands for these Syncro models are notorious for breaking. If your shaver charges direcly fom the cord but not the base, it sounds like there is an electrical problem with the base...probably the circuit board is bad. Parts that you would need to fix it are no longer availale from Braun. You will need to replace the unit. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Aug 28, 2011 | Braun Syncro 7526 Electric Shaver
I am wondering if I can buy a replacement cleaning stand and power cord for the Remington Titanium R 9500? I have the shaver but no stand or power cord and please may you send me the cost of it or where...
The cleaning and charging stand is no longer available for this model. However, you can charge this model directly from the charging cord. You will find this cord available at shaversource.com with free shippin in the US. See link below
http://shaversource.com/shaver-replacement-parts/remington-rotary-tct-ms32000-more-charging-cord-p-131.html
May 19, 2011 | Remington Titanium SmartSystem R-9500...
I have a Braun razor, 8585. When I connect the stand to the power, the light indicating the level of fluid come one and is accurate. When I put the razor in the stand, the charge light flickers but no...
Try removing the cord from the clean/charge base and plug the cord directly into the bottom of the shaver. If it charges directly from the cord, it is a safe assumption that the clean/charge base is not working correctly.
This unit is not repairable as the problem is, almost certainly, a faulty circuit board. You will need to purchase a replacement.
You will find a replacement clean/charge base for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Sep 25, 2010 | Braun Health & Beauty
Braun Syncro 7526 Electric Shaver Logo
1,739 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
