Question about HP Office Equipment & Supplies
Deskjet F380 printer unable to print claims paper jammed cheched printer no paper jammed all other ptinter functions ok
  • 37 Answers
Hi
Seems to be problem in sensors for that you need to open the printer and clean the sensor, If you are not expert in that then please check service centres for servicing.
Boopathy.T
Posted on Aug 17, 2008
Even after removing thye paper the status shows papaer jam. and unable to print
Try to use some compressed air, on the back inside of the printer, probably one of the sensors is jammed with dust or a tiny piece of paper.
Dec 05, 2010 | HP DeskJet F380 All-In-One Printer
Why my hp deskjet 2300 paper jam
please your printer in paper tray in out of paper and open the head couver and so the fixing in apaer. and printer is off and next time on and aply print is ok.
Oct 22, 2009 | HP DeskJet F380 All-In-One Printer
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Hp deskjet f380 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | HP DeskJet F380 All-In-One Printer
F380 deskjet - error - refuses to pront
I have this printer with the same problem , worked fine for 1 year, printed over 1600 pages total ( according to the built in HP program that records how many pages I printed and how many times I used the printer) then it stopped printing. The ink cartridges are new, the software is fine, and it says ink levels are good. It physically goes through the motions of printing, loads the paper, makes all the normal sounds it used to and pushes out the paper when it's done - but the page is blank. I did some surfing and read some info that some HP printers are pre-programmed to stop certain functions so you buy a new printer. I know that might sound crazy. How long have you had the printer and how many pages do you think you printed?
Nov 09, 2008 | HP DeskJet F380 All-In-One Printer
F380 All-in-one Deskjet
What sort of document are you trying to print (Word document, Excel spreadsheet, something else)? Also, what kind of paper are you using? Certain types of paper can stop progressing through the printer for a variety of reasons, regardless of the document type.
Thanks.
Sep 25, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380
your paper jam sensor is strucked or dislodge.please open it and check or send it for service
Apr 10, 2008 | HP DeskJet F380 All-In-One Printer
Hp F380
Pl. HP Deskjet F380 Printer Drives (Full Drivers)
Feb 16, 2008 | HP DeskJet F380 All-In-One Printer
Seeker5211
Seeker5211
