Question about Nikon D50 Digital Camera with 18-55mm Lens
Camera turns off. if i take out battery and put it back in i get err message. it will work for about 8 pics then it turns off again
  • ksenia11 Aug 29, 2008
    I have a similar problem.  Even when my battery is fully charged, my camera only takes a few (50 or so) photos (no flash) and then turns off.  When I take the battery out for a second and put it back in immediately, the battery symbol looks full again and the camera takes a few shots (3-5) and turns off again.  I can keep taking the battery out like this for an hour and the camera continues to act the same (shoots for only a few shots at a time).  I have tried to use a different battery and a different charger -- same problem.  I have had this camera for almost two years and this is the second time this has happened (both within the last couple of months).
    Problem Solver:
  • 9 Answers
I would definitely contact Nikon support about this one. I've never contacted them, so I don't know what it may cost, but it sounds like an electronic failure. Most likely, it's a resistor going bad and the camera is shutting off to prevent overload, or it's simply a failure in the voltage detection. But I wouldn't advise continuing to use the camera until speaking w/ Nikon. Also, your camera may still be under warranty.
Posted on Nov 20, 2008
ERR comes on screen...
Pull all the batteries, wait 30 seconds, put in a completely different card, put batteries back in and turn on and format the card--sometimes works
Aug 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
I keep getting error 99. I've cleaned the sensors with a new eraser; I've changed the battery and changed the memory card. If I take out the battery and put it back in, I can take a picture. If I pause for...
Hello:
Here is what Canon said :
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
I hope this will help
please don't forget to rate !
Mar 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
I shot a wedding and got the ERR message 3
Take your manual reset a little further...remove the card and battery...press all the buttons...leave the camera alone for at least 20 minutes...insert the card and then the battery...turn it on. See if that works.
Oct 08, 2009 | Nikon DSLR D90 Digital Camera
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
following:
steps:
camera body.
May 25, 2009 | Canon Cameras
ERR 99
try cleaning the battery contacts and the contact spring tabs in the battery compartment... also visually check to make sure the tabs are sticking out to make good contact with the battery terminals.
Also here's an excerpt from a canon blog ..it's a quote from a Canon usa service guy...
hope it's a help for you..
One of our participants in the long comment thread below (Tom) got this in a message from Canon USA. It may help some of you isolate the problem before you post a comment/question.
To isolate the cause of the issue, we suggest that you do the following:
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
May 25, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 in Canon EOS 350 D
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: -
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon Rebel XT EOS Every time i take a pic I get an Err 99. I have taken the battery out and memory card for 5 Min. If i do that I can take about 5 or 6 pics before I get that message again. What...
Try the following diagnosis steps: -
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D50 Digital Camera with 18-55mm Lens Logo
23 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
