Question about Daewoo KOR-1B4H Microwave Oven
Circuit board went dead
I had been heating some food & paused it to stir. Went I pressed start, everythign went dead. no clock, no response from any button... a fuse? a replacement circuit switchpad?
  • fearie_jae Nov 20, 2008
    my problem is almost the same. as soon as i opened the door to the microwave, it turned off everything on that circuit breaker so i had to flip the breaker. when i did, everything else came back on except the microwave. what would i need to replace in my case?
  • Anonymous Mar 18, 2014
    I was heating up some food and it just went dead.
  • Daewoo Master
  • 9,086 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
And it will need a fuse, too.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
You can visit Daewoo online or call them at 1-800-323-9668 or 1-800-553-4355 to find parts or find your nearest authorized service center to have them do the work.
Posted on Aug 18, 2008
Microwave went dead as soon as I started heating. Replaced its fuse:58001220
The klystron or the hi voltage transformer are faulty. The klystron is the part that generates the microwaves. The transformer supplies the voltage to operate the klystron.
Dec 31, 2014 | Microwave Ovens
GE JVM1430 Spacemaker is dead. Completely.
See my microwave oven safety file here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. How to test a high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. My door switch help file.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
If the fuse is easy to twist with your fingertips while it's in the holder, it's too loose.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 29, 2017 | GE JVM1430 Microwave Oven
Microwave went dead
Hi
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | Whirlpool MH7140XF Microwave Oven
Demo mode
I had the same problem trying to get rid of demo mode. Press the "clock" button 3 times in a row and problem fixed!
Jun 19, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave completely dead
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 04, 2007 | Maytag MMV5165 Stainless Steel 1000 Watts...
Faulty microwave oven
So it's dead? (No lights, no beeps when you press a key?)
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
But - this model uses and inverter. Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
But if you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 08, 2007 | Panasonic NN-S254BF Microwave Oven
Frigidaire Microwave
Dead? You mean no power, no lights, no beeps, nothing?
It's most likely a blown thermostat / thermal cutout on the magentron, based on your info.
But if you can post the model number I may be able to steer you better.
More generic info:
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 28, 2007 | Microwave Ovens
Panasonic microwave s254bf stopped working
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 21, 2007 | Panasonic NN-S254BF Microwave Oven
Daewoo KOR-1B4H Microwave Oven Logo
233 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
