Hi.
I don't know if this is the case or not, but most burners will fail if you try to use an off name type of disk.
I have had a burner in my computers for several years now, and here is what I have found.
TDK, Maxell, and Dynex brand disks work almost every time.
Sony disks work most of the time, but only at lower to medium speeds.
Memorex disks are a crapshoot, you could have a stack of 50, and maybe 3 or 4 will fail, and then again, maybe 15-20 will fail.
GQ brand works great at slower speeds, but fail alot at high speeds.
Also, you may want to invent in a lens cleaner disk, as it might be that three is dust and dirt inside your burner, and that is what is causing your burner to fail out no you.
I hope this helps you out, and good luck to you.
