Question about Dishwashers
My dishwasher doesnt drain water or wash the dishes in the dishwasher.
    Scholar:
  • 132 Answers
Water not draining - sounds like a blockage (food content)
Does not wash - - I suspect there is some LOGIC in the dishwasher that knows that it can not drain - therefor will not fill with more water until that problem is resolved..
Good luck
Posted on Aug 17, 2008
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
Low water level
Try to unstick the float. The float tells the DW how much water is in it at any given time. It is shaped like a mushroom on the bottom of the DW basin. Gently pick it up and set it back down. Does it seem free? Try the cycle again.
Jan 10, 2014 | Samsung DMT400RHS Builtin Dishwasher
Food particles remaining on dishes after cycle is complete.
Hi
While putting dishes in the washer and obstructing the spray ams which causes food particles to stay on dishes. After loading dishwasher and pushing in baskets ,be sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
However the other causes for this problem are…
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 14, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My Maytag Performa recently stopped washing the food off the dishes. It fills and drains like it is supposed to, but seems to not have the right pressure.
Before drawing any serious conclusions check wash arms for blockage in spray holes, < possibly slowing delivery of water pressure > it can be calcium from hard water.
Apr 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Fills with water and drains will not run to wash dishes
The main water pump is not working. A repair will be pricey. it may be best to get a new dishwasher
Apr 21, 2009 | Dishwashers
GE Dishwasher
It could be a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle,it pushes the water out of the dishwasher. The motor and pump are located beneath the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around freely. In case it doesn't spin freely, look if it doesn't blocked or stuck from any other reason. Good luck!
Sep 10, 2007 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
205 people viewed this question
Top Dishwashers Experts
