Question about GE 24-7/8" Convertible Portable Dishwasher - White-on-White
GE NAUTILUS DISHWASHER
WATER DRIPS UNDERNEATH UNIT AS SOON AS IT STARTS , HAVE REMOVED UNIT AND CHECKED ALL HOSES AND CLAMPS ALL OK . UNIT DOES NOT LEAK UNLESS IT IS RUNNING,
The motor seal is leaking, had the same problem with mine.
Posted on Dec 01, 2008
    Scholar:
  • 132 Answers
Sounds like the water outlet has a leak - probably a simple 'o'ring problem - these can wear.
Posted on Aug 17, 2008
Temperature gets really hot. when radiator cap removed, water drips lightly from underneath vehicle.
See if you can determine whether the water is coming from the water pump. There is a weep hole at the top of the pump that shows a small amount of water when the pump is going bad. If that is the case, you will need to replace the pump. Check all hoses and clamps to see if they are the source of a leak. While you are at it, you may consider whether it is time to replace the belts and hoses if they are more than 3 years old.
Sep 19, 2010 | 1991 Ford Explorer
No water goes into dishwasher
Check the water inlet solenoid, it may be sticking/stuck Soak in a bit of WD40 or CRC. and, try a bit of percussive maintenance, IE: give it a "bit of a whack"
Feb 09, 2010 | GE Nautilus 24" Built-in Dishwasher
My dishwasher doesn't seem to be washing correctly - it heats up but there is hardly any "water" noise going on in there it's like it doesn't spray around in there like it should -- as soon as it starts...
You might have a clog at the water source. Where the water attatches to the washer there should be some kind of screen in it. Try and find it and clean it out.
Oct 21, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher gsd2200g00ww water supply valve
dishwasher g e model GSD2200Z00AD WON'T DRAIN WATER
Jul 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Water standing in the dishwasher at end
probably cant fix this your self. if your sink is draining ok then you probably have a problem with your circut board.
Apr 25, 2009 | GE Nautilus 24" Built-in Dishwasher
Antifreeze dripping off front of block on 1993 Eagle Vision
when the water pump starts to fail it leaks out of the weep hole that is built in as a warning . plan to replace it soon.(obviously check simple stuff first- hoses, clamps...0
Jan 20, 2009 | 1993 Eagle Vision
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
GE 24-7/8" Convertible Portable Dishwasher - White-on-White Logo
323 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Ned Halaweh
Ned Halaweh
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
