My Dell does not recognize my wireless connection.
  • Jason Carver
    Jason Carver May 11, 2010
    It could also be an incompatible wireless spectrum.
  • Steve Si
    Steve Si May 11, 2010
    Is your router set to use WEP or WPA or no encryption?
    Problem Solver:
  • 16 Answers
First of all make sure your dell "sees the wireless network, if it does - go back to your router program, write down all pertinant info needed for the dell under wireless network connections; SSID, encryption password, type of encryption, etc. fill in the info you wrote down. That should fix it.
Posted on Aug 17, 2008
Dell inspiron m5030 netgear router
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Jan 23, 2013 | Dell Inspiron Computers & Internet
My laptop recgonizes the wireless network but it will not connect to it.....help please.
After it recognize it you have to pick the wireless connection you what to use, go to the bottom corner, of the lap top and open the wireless connections, and pick the right one to use.
Jun 08, 2011 | Dell Inspiron E1705 Notebook
Connection wireless adapter to laptop dell
Open up PC, Plug it wireless network into a PCI slot, turn on PC, the network device will be recognized and ask for drivers, you insert the CD/DVD that came with it, or use the software you downloaded from Belkin web site and install the WiFi card.. Run the Belkin software and it is installed. reboot PC, put case side back on.
Mar 02, 2010 | Belkin (F5D7000) 802.11g/b Wireless...
I have a Dell Inspiron B130 Laptop that I'm trying to connect wirelessly. It's not recognizing our home wireless network but my husband's laptop does. What can I do?
First of all make sure that your antivirus software firewall is not blocking it.
I suggest you uninstall all the antivirus softwares your pc has completely first and then restart your pc and see if your laptop recognizes the wireless internet.
let me know the result.
Thank you for using fixya.
Jan 29, 2010 | Dell Inspiron B130 Notebook
Dell Latitude D510 Wireless Connectivity Fades/Dies
There are wrong settings of your wireless network with your Dell latitude d510,you need to recorrect it .
Jan 27, 2010 | Dell Latitude D510 Notebook
Dell wireless keyboard stopped working. Changed
I make oresumption that you have depressed the connection button under the keyboard to reset it?
If still a problem go to device manager and delete the wireeless keyboard so it can be discovered again.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
I have a dell wireless mouse and it used to connect with my computer and work fine. I've had it almost a year but now it will not connect to my dell laptop. The light on my laptop and on the mouse will...
Most wireless keyboards and mice have their own wireless receivers (one that should be connected to the computer). The wireless receiver usually has a connect button that you need to press in order for you to connect the keyboard or the mouse. Try holding down the connect button on the receiver and on the keyboard at the same time for five seconds and release them both after five minutes.
If that work, do the same for the mouse.
Hope this helps and have a great day!
Jul 06, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My dell latitude d600 is not recognizing any wireless connections. I believe the switch is at top of the keyboard and it doesn't seem to be working. Any advice
if it is not seeing any wireless networks, the wireless card may be defective, try having it tested, or check the device manager to make sure the drivers are installed correctly for the wireless network adapter
Jun 27, 2009 | Dell Latitude D600 Notebook
My internal wireless adapters will not connect to WPN284 wireless
Make sure the default gateways and DNS servers options for both wifis point to your wifi router
Mar 30, 2009 | NetGear RangeMax WPN824 Router
Dell Wireless 2350 BroadBand Router
You may get some benefit from downloading and installing Netstumbler
This util will allow you to scan the channels and select a chanel with less devices on it. then change the broadcast channel in the wifi router. This may reduce interference in the connection.
Also cordless phones are notorious for interfering with wifi routers so put some distance between the router and the base if you can.
Another option is to get an external antenna for the router to boost signal strength
something like THIS or THIS and place up high on a shelf. Just check your router antenna is the sort that comes off... should unscrew. not all do unfortunately so be careful not to break yours!!
BTW - the router is not a bad unit but it also is not the best around either REVIEW
Jul 19, 2008 | Belkin 802.11b Wireless Notebook Network...
Computers & Internet Logo
David Payne
David Payne
