Question about HP L1706 17" LCD Monitor
Blank screen, but has power
My monitor has power, but the screen is blank. If I turn the monitor off and back on, the screen comes on dimly for a few seconds, and then its back to a blank screen.
    Scholar:
  • 133 Answers
It is most likely a backlight that has burnt out or something else of the sort. You will want to call HP Support and explain to them of your troubles.
Posted on Aug 17, 2008
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
The monitor goes blank after a few min, it comes
Are you sure that your computer isn't just going into power saving mode? Not sure what operating system you have but go into the screen savers tab or video properties and find out how your system is set up for power saving It may be starting before your screen saver does so the monitor would just go black.
Dec 18, 2009 | ViewSonic PF775 17" CRT Monitor
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Monitor sometimes goes blank
it looks like the inverter board is going out on the monitor.. if u seach on ebay or somewhere they sell inverter board order one u can probably change it yourself.. i 'm 95% thats the problem
May 07, 2009 | Acer Computers & Internet
Screen goes blank while typing
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5315 Notebook
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
HP L1706 17" LCD Monitor Logo
588 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
