Question about Cameras
Olympus stylus 810 lense won't retrack to close. camera drop on lens and don't know if other damage is done
    Genius:
  • 1,142 Answers
It will not even be covered under warranty so go ahead and open the unit and reallign the lens which will fit very easily and can be fixed too.
Posted on Aug 17, 2008
    Brigadier General:
  • Cameras Master
  • 3,614 Answers
It is possible that you have damaged the camera.. and could be a misaligned parts on the retructor, just try to slam/slap the camera on the lower back, while press the retract button..
    Genius:
  • 1,447 Answers
Hi-
Chances are if you drop the camera is that a part inside of might gotten loose or broke. Look for any physical damage on the lens itself, check for dirts that might prevent lens to retract, if all fails then that means it broke and you need a technician to open it up. If its within warranty, never attempt to open it up and call manufacturer instead.
Thanks for using Fixya!
    Master:
  • 848 Answers
You are having sensor problem in your camera ...........
Don't know how to remove and swap lenses on my olympus sp-590uz
The lens isn't supposed to be removable. With the CLA-11 Adapter Tube you can add an additional lens to the camera, such as close-up, wide-angle, or telephoto. However, these attachments go in front of the lens that is already on the camera.
Jul 29, 2011 | Olympus Cameras
HAVE olympus 1010 stylus and the lens won't pop out. when I push the power button, it makes a sort of dragging chain sound and then 4 sort of "chimes". Looking at it facing front, the lens...
The internal plastic gears which govern the lens opening and closing are either damaged or out of alignment - this happens when a camera is dropped or has any other form of physical interaction for which it is not designed.
Jun 26, 2017 | Olympus Stylus 1010 Digital Camera
Camera will not stay on, lens retracks.
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean both ends of the batteries, place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 04, 2010 | Olympus Camedia Stylus 300 Digital Camera
Zoom error olympus sp-310
no the memory card is not the problem .... the internal gears or blocks which intialises the lens may have been dislocated due to which this problem is occuring ,..... it has to be fixed from a repairman ,....
Dec 07, 2008 | Olympus Stylus 700 / 700 Digital Camera
Olympus Stylus 600/Digital 600 6.0 megapixel
Hi
This camera can be very picky when it comes to the front lens cover... It's not a simple mechanism and has many small parts and gears involved. If the lens cover is dislodged it won't work smoothly, and if the case is dented it will not be able to move properly and this can cause lens problems.
If the lens was out when the camera was dropped, then it's possible the lens was damaged and not the lens cover. Sometimes you can tear down the lens, clean it and rebuild it and it will work smoothly again, sometimes this doesn't work and the lens needs to be replaced.
If you're comfortable opening the camera, first check out the lens with the front body section removed so nothing is blocking the lens cover. Does it work properly now? If not, then expect lens damage to be the issue.
We are an AFFORDABLE digital camera repair shop... if we can assist you with parts or do the repair please let us know. (google: darntoothysam)
Hopefully this is of some help. Even if you don't use our services please feel free to let me know if you need more assistance.
Good luck from Darntoothysam com
Thomas
Oct 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Olympus Stylus 710 Error: D: 5f08 5f0a 5e02 5f08 5e02
this is the most common problem with the olympus cameras the lens has been knocked and by you pulling on the lens it sounds like you have done some damage to the motor that bring the lens in and out thats why its making that noise what you needed to do was move the lens either to the left or the right you will no when its fixed because the lens just pops out and the camera will be fine this works every time i just hope you havnt done to much damage alredy goodluck
Sep 21, 2008 | Olympus Stylus 710 Digital Camera
Dropped Camera - Lens won't close
Generally speaking if your camera cost $500 or less, and you can't fix it yourself, it is cheaper to just buy a new one.
Jun 30, 2008 | Olympus ? Stylus 500 Digital Camera
Broken camera
It is likely that your lens assembly was knocked out of alignment when you dropped the camera. When things do not line up inside the lens the whole unit cannot move in and out. This malfunction requires disassembly to fix, so you will have to get it to a professional for repair. There are providers online who can repair your camera, and also check with your manufacturer to see if they can service the camera at a reasonable rate. David Millier Advance Camera Repair
Mar 05, 2007 | Olympus Camedia Stylus 300 Digital Camera
My camers is stylus 500 but this was nearest description I could find
dropping of camera, especially on the lense side, gives damages to the lense barrels and their pivots. The moving barrels have small pin like projections which move into the grooves cut into the exterior barrel. when dropped either these pins get broken or they come out from the grooves due to the heavy jerk. If disaligned these can be set back to their normal position without much labour charges but if broken the whole assembly is replaced thus causing lot of payment.
Sep 23, 2006 | Olympus Stylus 700 / 700 Digital Camera
Cameras Logo
43 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
