Question about Maytag PYG2300A Gas Dryer
Broken belt that turns the drum
Need help on how to install new belt
  • kant-boom Aug 22, 2008
    hi as any one got a diagram of how the belt gose on a hoover hnv 160 dryer
    Problem Solver:
  • 8 Answers
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!broken belt that turns the drum - 0798e0b.jpg
Posted on Jan 09, 2009
Need information on replaceing the belt on a Gas Maytag dryer, Model PYG2300AWW
Posted on Nov 14, 2008
5 Suggested Answers
mikesagenius
  • 24 Answers
SOURCE: frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Posted on Jun 03, 2009
  • 9 Answers
SOURCE: Gas dryer gets hot but the drum doesn't turn. Broken belt?
open the door to the dryer and inside the rimof the door there is a switch, puch the switch in and with the oppisite hand puch the start button on the dryer. if the drum does not spin then you know its the belt. Pull Lint vent out if top mounted and remove the 2 screws, Between the top of dryer and the front panel, stick a putty knife roughly 3 inches from the side of dryer. There are locks that you will unlock with putty knife. once top is removed at top corners of front panel inside you will find 1 swcrew on each corner, and pull off front panel, slip new belt in and start putting things back together.
Posted on Jul 27, 2009
MARCLAVORIS
  • 110 Answers
SOURCE: belt broken, drum wont turn manually
if your drum will not turn manually, then the motor is seized up, or a sock is caught in the blower wheel...
Posted on Sep 16, 2009
marka19
  • 1430 Answers
SOURCE: Maytag DE303 dryer installing the drum belt
No don't lube the idler pulley replace it. There are videos at www.appliancehelponline.com/servicemanual.html that can walk you thru the disassembly and also on replacing the belt. You can also enter in your model # for diagrams and illustrations.
Posted on Apr 09, 2010
My dryer just started making a loud sound and the drum isnt turning
Could be the drive belt has come off or is broken or if it is gear driven, then it's possibly the gearbox has failed. New belt a piece of cake, new gearbox?, time to price it against a new dryer.
Dec 05, 2014 | Haier HLF11P 6 cu.ft. top load washer /...
Tip
Kelvinator Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs
Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
Tip
Gibson Dryer Belt Diagrams and Replacement
Style: Flat belt
Hi Im having a problem with my dryer..........Its getting hot and everything but the drum on the inside is not turning so only half of the clothes are getting dry.Can you help me?
Almost certainly the belt has either slipped off or has broken.You need to ask an appliance tech to check it if belt is broken as the electrics have to be disconnected and drum removed to install new one.There is a belt tensioner on some of the units as well.
Aug 09, 2010 | Whirlpool Dryers
Help Changing Belt on Maytag PYET444AYW dryer
Normally if it is a front loading machine then you need to take the front of the dryer off.
This will expose the drum, roller, etc.
Remove the drum, install new belt on the motor pulley, loop around the idle arm roller, then install on the drum and reinstall the drum, reinstall the front and job complete
Sep 26, 2009 | Maytag Dryers
Tip
Hotpoint Dryer Belt Diagrams and Replacement
For Hotpoint Dryers
1970- 1990 standard capacity
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
1b9906a.gifStyle: Flat with ribs
Tip
Roper Dryer Belt Diagrams and Replacement
For models with non-removable back panels use this diagram:
For models with removable back panels use this diagram:
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Tip
Whirlpool Dryer Belt Diagrams and Replacement
Tip
Kenmore Dryer Belt Diagrams and Replacement
For Kenmore models starting with 110 or C110 with a removable back use this:
For dryers starting with 110 or C110 with nonremovable back use:
For Dryer models starting with 417 use:
Open Questions:
Maytag PYG2300A Gas Dryer Logo
1,240 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
