Question about Whirlpool LSR5232L Top Load Washer
Whirlpool american washer
I need to install thsi machine, but have lost the install imstructions during a house move. Waht height do i need to have the drain pipe - the on ethat connects into the main drains?
  • 770 Answers
Go to www.whirlpool.com to get the install book
Posted on Aug 17, 2008
6ya staff
SOURCE:
Washing machine won't fill on rinse/spin cycle
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.81878110&pathTaken=partSearch
I'd also see the Whirlpool / Kenmore Service manual for these washers. It has a troubleshooting section as well as test specs.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It sounds like a timer problem but I'd go thru as many of the Whirlpool test as I could before spending the money.
Also see the following on how to release the console to gain access to the components.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Also see the following "diagnostics chart"
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=133
Mar 28, 2010 | Kenmore Washing Machines
Washer doesn't agitate or spin. Ican not move the agitator by hand.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Mar 21, 2010 | Kenmore Washing Machines
I am looking to buy a used 4 year whirlpool duet washer and dryer. Do you need transport bolts to move either? Also what capacity is the washer and dryer
The transport bolts are required to be installed before transporting the machines. This is to support the suspension system to prevent damage to the machines during transportation.
The washer has a capacity of 9.0 kg or 19.8 lbs with a volume of 3.7 cubic feet. The dryer's capacity is 7.0 cubic feet.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Moving whole body of washing machine madly
the platform where your machine was installed is not leveled correctly, you need to identify which part need to be adjusted, you can adjust the roller height manually or place some shims to level this unit correctly
Jan 06, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I moved my whirlpool washing machine to a new location in my house and it now stops after filling and won't wash. I have turned the feet knobs to make sure they all touch the floor and changed the hoses...
ckd lid switch ..lift lid and slowly close listening for faint click..newer models have lid switch under top at left lid hingeand will not agitate or spin if lid is open..also ckd motor wire4s to be sure they are snug moving the washer may have caused them to come loose..ck hinge screws to be sure thsy are tight
Jul 26, 2008 | Whirlpool Washing Machines
Moving
you just need to refit the transit bolts which you removed when you had machine new. if you have lost them, pack some polystyrene blocks between tub and cabinet so the assemby is held tight
Jul 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer discharges Water during Agitation
you might consider raising the washer about 6 inches to make this work. it's vital to the operation of the machine..
Mar 09, 2008 | Maytag MTW5600TQ Top Load Washer
Whirlpool LSR5232L Top Load Washer Logo
44 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
