Question about Whirlpool MH1150XMQ Microwave Oven
MH1150XMQ Lower Light Stopped Working
The light that shines down over the stove went out. I went to change the bulb and the glass part broke off, leaving the metal part in socket. After trying to get it out, ruined it and had to replace the whole light socket.
I took the old socket off, leaving the two wire leads exposed and they touched, causing a little electrical short (leaving little scorch marks on metal ends of leads). I then (should've done this first - doh!), cut the power to the microwave and installed replacement socket, slipping the leads back on the prongs of the new socket, but the light won't work at all.
I checked the only fuse I could find in the unit (behind the control panel) and it was okay. Does anyone know if there's more than one fuse in the unit, and where it may be - or do you know any other reason that would keep the light from turning on now? Really would like to get that lower light working again. Thanks for your help.
  • hootmonkey Aug 17, 2008
    The complete unit# is MH1150XMQ-3:
    1) The light that shines down over the stove went out. I went to change the bulb and the glass part of the bulb broke off, leaving the metal part in the socket. After trying to get it out, ruined it and had to replace the whole light socket.
    2) I took the old socket off, leaving the two wire leads exposed and they touched, causing a little electrical short (leaving little scorch marks on metal ends of leads). I then (should've done this first - doh!), cut the power to the microwave and installed replacement socket, slipping the leads back on the prongs of the new socket, but now the light won't work at all.
    3) I checked the only fuse I could find in the unit (behind the control panel) and it was okay. Does anyone know if there's more than one fuse in the unit, and where it may be - or do you know any other reason that would keep the light from turning on now?
    Really would like to get that lower light working again. Thanks for any electrical insight or help you can offer to this problem.
  • nerkowski Nov 11, 2008
    I have the same problem except I'm not getting any power to the unit what-so-ever!
  • Whirlpool Master
  • 8,871 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
I have a mh1150xm microwave and changed the cooktop lightbulb. Still no light. A tech came and said that need to change whole control board. Is this true. Everything is working fine exept the light
I take it you did replace with a bulb designed to withstand heat.check the filament of bulb first these sometimes get damaged in transit.if the microwave is coming on then it won't be the fuse.if the bulb looks okay(you can check using another) finally inspect the door latch and the bulb housing and wiring to it.Sometimes door latch hole can get debris into the mechanism.cost of panel via engineer can cost quite abit..is it still in warranty? Price compare the estimation against buying new replacement.
Feb 09, 2015 | Whirlpool MH1150XMQ Microwave Oven
How to change the hood light
By hood light I assume that the light you want to replace shines from the bottom of the unit, not the light inside the microwave. If so check out he Disassembly video on this site: Maytag Microwave Light Bulb Not Working
Jan 02, 2015 | Maytag MMV5207BAW Microwave Oven
The light bulb in my emerson 8997B stopped working. It had come backThe light bulb in my emerson 8997B stopped working.
Buy a different brand of Microwave. This is ridiculous! We are now buying a new microwave - a different brand, one that has a light bulb that is easy to change
Dec 16, 2012 | Emerson Black Microwave Oven
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do I change the light bulb in the microwave - the one that shines above the stove? I removed the covering and tried to remove the bulb but it doesn't seem to unscrew and the bulb just came out - no...
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "how to change cooktop lamps" for example.
Nov 24, 2009 | Roper MHE14XKB Microwave Oven
All the light blew out, the electric still works, but the oven won't heat food
Hi, my living room light has stopped working, When i turned it on one of the little bulbs went pop and light stopped working although all electric and other lights still work. I tried the bulb in a different light and it still works as well?? I also took light off to check for loose wiring etc but all seems to be fine. Can you help? Thanks!
Oct 04, 2009 | Whirlpool Accuwave Microwave Oven
Broken light bulb
Go to an appliance parts store to get the bulb.
Good Luck and Please rate fixya!
Feb 23, 2009 | Jenn-Air JMV8208A Microwave Oven
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
76 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
