Question about Lands Phones
While updating the 3g iphone, some error occured and it told me to restore the phone to origional settings. I did this and half way through the restore it came up with an unknown error and stops. Then tells me to restore again and the same thing happens.
  • pigfly Aug 17, 2008
    I didn't think you could take the battery out of an iphone?
    Master:
  • 848 Answers
Just remove the battery and after 30 minutes reinsert the battery and update to the latest version .......
Posted on Aug 17, 2008
WHEN I TRY TO SEE RECENT CALL HISTORY THE I PHONE 3 GS REVERTS TO THE HOME SCREEN. IS THERE ANY WAY OF RESOLVING THIS?
hello,ensure you are not clicking on the key wrongly,i would advice you put the phone off and on back to see if the problem stops.if it doesn't i would also advice you ensure you close any application you are not making use of.it could also be as a result of accumulated opening of applications. if that does not stop the problem,i would suggest you get the phone flashed by a mobile phone authorized repair engineer around you.
wish you good luck,
take care.
Jun 30, 2011 | Apple iPhone 3G
Help on frozen iphone 3.1.3...want to restore
just switch off your phone and press home button and connect to cable and restore it from there it would get solved
May 25, 2010 | Apple iPhone 3G
Freezed updating
the iphone 3g has alot of problems internally... you should keep the old version....
Nov 22, 2009 | Apple iPhone 3G
Tried restoring iphone on my itunes account and it said "restore failed" my iphone is totally disabled and I am unsure how to fix this problem
When your restore fails, it usually tells you, Your iphone could not be restored, an unknown error occured(number). Get that number and either post it on here or call 800 my iphone with it.
Oct 03, 2009 | Apple iPhone 3G
I want to know the code for Restore Factory settings for my 3G iPhone
You can either go to settings -> general -> scroll to the bottom "set to default"
Here you can choose what to reset.
OR you can restore the firmware of the device (this will erase all data on it, music, videos, pictures, bookmarks, wifi-keys...)
To set your iPhone 3G back to factory settings, just connect it to itunes and wait for the device to appear. Click on the iphone and you should see the screen that tells you how much more space you have left etc.
In the middle of that screen you have the options to "search for updates" and for "restore" .
Click on restore and wait. (If you have never restored or updated your iPhone, itunes will download the most recent firmware from the internet, this may take a couple of minutes)
Once its done, the iphone will restart and reconnect to itunes.
Itunes will ask you if you want to restore (if you have any backups) or treat it as a new phone.
Select treat as a new phone and give it a new name. Now everything is back to factory settings and all media, settings and accounts are deleted.
Jul 03, 2009 | Apple iPhone 3G Black Smartphone
Iphone will not restore
try respring it (central + power buttons together and then connect to iTunes in safe mode,choose full restore (it will erase everything but if you have back up can be restored).
May 12, 2009 | Apple iPhone 3G Black Smartphone
IPhone 3G Error 0xE8000001
Where did you purchase your phone? however, you first need to update itunes to 8.0.2, that might solve your problem. Unless you have an unlocked phone then restoring your phone is useless because when you restore an iphone with itunes in the US without an att sim card it will actually lock the phone, but I do not think that is your issue. the two things you are seeing the connect to itunes and the emergency call system means that your phone is not properly activated. which is done by connecting it to itunes.
Jan 20, 2009 | Apple iPhone 3G
Try restoring in DFU mode, which is different than recovery mode. I happened to stumble across it while trying to restore an iPhone 3G that a user unplugged in the middle of the 3.1 update. It kept showing an error of 1611 or 13 and wouldn't restore in recovery mode. I found this DFU mode option and the restore worked fine. The DFU mode keeps the iPhone OS from loading, so you don't run into as many compatibility problems. Go into DFU mode, then try restoring the phone and see if that works.
http://techierambles.blogspot.com/2009/09/restore-iphone-with-error-13-or-1611-in.html
To enter DFU mode:
1. Connect your iPhone to your computer
2 . Turn iPhone off. You may have to hold the power and home buttons down together to force the phone off
3. Once the phone is off, hold the power and home buttons together for 10 seconds exactly
4. After 10 seconds, release the power button but keep holding home until the computer recognizes that a USB device was plugged in
5. iTunes should detect your iPhone correctly, and also allow you to restore to the factory default settings
Mar 02, 2008 | Apple iPhone Smartphone
Lands Phones Logo
71 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
