Question about Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe grinder problem
Hello, i have a saec magic deluxe. this is the first time it has happened, i maek my usual coffee and when i press for my coffee, the grinder starts, it seems to be working , however it does not stop grinding and when i check it is not grinding any beans at all, it just makes the whirling sound. help!!
cindy
  • aurorama Aug 21, 2008
    My problem with my Saeco machine is as follows:
    When I press the espresso button - it makes a grinding noise and it takes several times (sometimes up to 6) to get the coffee flowing through.
  • 515 Answers
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Posted on Aug 17, 2008
Panel won't light on Saeco Magic Delux
Sounds like a board issue. It was something that happened on the Saeco Magic Deluxe's enough to be noticed. The board is not available for magic deluxe's with oval buttons.
Parts for your magic deluxe
May 29, 2011 | Saeco Magic De Luxe Espresso Machine
Tip
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
Two weeks ago I paid > $100 for a full service (Saeco Magic Deluxe) and now the machine won't grind the coffee beans. Any suggestions so I can be a bit "knowledgable" if I need to take it...
Hi
If the grinder is spinning your grind set is too fine. Push the lever below the bean hopper to the back. It can go to a coarser setting anytime but the grinder has to be spinning to make it finer. They may not have set the grinder correctly. Have them walk you through the process. It also takes about 2 to 3 times before the grinder fills to work.
Apr 13, 2011 | Saeco Magic De Luxe Espresso Machine
My magic deluxe is grinding very coarse on number "1" grinder setting and the coffee is very weak; do you think the grinder blades are blunt? the machine is 13 years old.
Hi
Your grinder has seperated. The cork screw in the center is not centered. Grinder needs to be replaced. If you want one let me know.
Jan 21, 2010 | Saeco Magic De Luxe Espresso Machine
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Our Saeco Delux Magic coffee maker will not grind the coffee when we push the button. A light comes on that indicates that the grinder could be jammed.
Hi
The grinders run on a timer. If the grinders does not fill the doser in time you will get a light saying no beans. If this happens and there are beans in the hopper push the lever to the largest # and push the brew button again. This will clear the light and it should brew. If it is at the largest # already your beans are probably shiny and there is to much oil in the beans and this is what is clogging the grinder.
Apr 10, 2009 | Saeco Magic De Luxe Espresso Machine
Magic Delux - Not heating
try to descale your machine to see if it helps.
Aug 24, 2008 | Saeco Magic De Luxe Espresso Machine
From 1-7 on the coffee grinder, which is the finest grind.I Hve misplaced my manual
1 would be the finest. I wouldn't recommend going under 2 though.
You risk clogging your grinder and machine under 2. There's also a dosage control when you open the door on the side. + means a bigger dosage or puck.
Hope this helps.
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
The Coffee bean holder
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions.
If the grinder cleaning does not work.. You may have to have to machine serviced.
Please include the model of machine and that you would like the grinder cleaning instructions.
Email: support@cerinicoffee.com
Oct 06, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Aug 20, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
586 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
