Phenolic bed plates are lighter than metal bed plates and
great for use in a printing press that uses water based ink because these types
of plates will not get rusty like metal plates will.
You need to buy a
special paint for metal with special additives that prevent rust. Make sure to also buy a primer that is compatible
with the paint you have selected. I
found you some great instructions that should help you out.
• Wipe
the wrought-iron bed frames with a rag that was dipped in mineral spirits. That
will help you to remove all traces of oil and grease from the frames.
• Scrape rusty
areas with a putty knife or scraping tool. Remove all loose rust scale. Rub the
surface with steel wool, too.
• Apply an oil-based primer. The primer needs to be designed for
use on metal surfaces such as wrought iron. Roll on the primer with a small
roller. Spread the primer with a paintbrush. Cover the whole surface with one
coat of primer.
• Paint the
bed frames with a finish paint that has a rust inhibitor within 24 hours of
priming them. That will help the primer and paint bond.
• Roll on the
paint in the same way you applied the primer. Use a paintbrush to make smooth,
sweeping strokes to distribute the paint. Switch to a paintbrush with synthetic
bristles if you decide to use a water-based paint.
Read more: How to Paint Wrought Iron Bed
Frames ' eHow.com http://www.ehow.com/how_7794293_paint-wrought-iron-bed-frames.html#ixzz232Q8GYhr
whats the make and model,, if it was made before 1963 it could be lead paint, if after that don't worry about it,, they had bans in place after that year
