The drivers side motor works but the other three windows may go down but not up
    Scholar:
  • 133 Answers
This section is for PC Desktops only. Your question is better suited in the automotive section :)
Posted on Aug 17, 2008
Electric window (driver side) works, but why not the other three?
Power Windows Not Working - Repair Power Windows
www.popularmechanics.com/cars/how-to/a69/1272371/
Another toll-booth, another mile--or at least it seems as if the tollbooths come every ... The most common power window mechanism is pretty basic. ... If the driver's door switch won't open the right rear door, but the switch in the ... direct from the battery positive terminal to the positive side of the motor to see if it comes alive.
Power Windows not working - CarGurus
www.cargurus.com > Questions > Honda > Accord
CarGurusOct 9, 2012 - I have a 2007 Honda Accord the driverside window works but other 3windows dont, but when u hit the master switch on drivers door to try to ...
I can only operate one of three power windows - CarGurus
www.cargurus.com > Questions > Chevrolet > Prizm
CarGurusApr 28, 2013 - Drivers side power window works only. Had a mechanic ... windowsnot working either. ... Already replaced it. all switches showing getting power but don'twork. ... Are you certain that the other three window motors are good?
Why Do My Power Windows Sometimes Stop Working ...
Dec 21, 2015 | Cars & Trucks
Drivers side window wont roll up or down
If you can hear the motor when you try to operate the window then it'll be a problem with your window regulator (the mechanism that moves the window up an down), if you can't hear the motor then It's more likely to be a fault with the motor as you said it wouldn't work with the central locking. This means your car has a total closure system, ie you press a button and all windows and sunroof close. These systems are usually seperate wiring from the switched circuit used to operate the windows from inside the car, so, if the windows don't work on either circuit then the one thing they do have in common is the motor.
myLightSmile
Dec 14, 2015 | 2008 Chevrolet Tahoe
2001 Aztek windows buzz
Sounds like your drivers side window regulator motor gear is bad as far as the other windows drivers door switch is most likely bad if you dont have experience working on electrical or have never taken apart a door panel I would recommend seeing a mechanic. To check the switch you have to disassemble passenger door panel accesa the window regulator motor disconnect the weatherpack connect hook up multimeter and test for power while having an assistant push the window switch down
Apr 11, 2014 | 2005 Pontiac Aztec
Vwpassat20006 1.9TDI, passenger side power window,keeps opening after it is closed from the drivers side, it can keep going up & down about halfway on Its own. Is there a "brain" printed circut...
the modules may need reset if that doesnt work it may need a module for the window motor to reset use switch run window up holding switch in up position until it has been up for 10 seconds then run down in the same manner do this for both front windows if this doesnt work you will need to take it where it can be scanned through the window modules usually vw dealer only has this capability unless you know someone with vagcom
Aug 20, 2009 | Volkswagen New Passat Cars & Trucks
How do you replace the motor for the driver's side window?
pull the door panel off and youll see where the window motor is . it usually is reveted to the frame drill the revets out and youwill be able to pull the motor out. sometimes you can buy a rebuild kit for them. inside the motor there are three plastic peices the get eaten up the rebuild kit has these pieces and it is pretty easy to fix. if you hear the motor working but the windows dont go up of down you may be able to do this type of fix if not then you have to buy a knew motor
Dec 01, 2008 | 2001 Ford Windstar
2000 GMC Jimmy SLE driver's power window
The same thing happened to my 1999 JMC Jimmy recently. I believe the problem is that your power window motor has most likely gone out or is starting to go out. The motor will need replaced. They are pretty expensive new. I went to a junkyard and got one for around 15 dollars. When mine went bad, I had rolled my window down about three or four inches and it stuck there. I took my door panel off and tapped on the motor while holding up on the window switch and got it to go up after a few minutes. I am replacing my motor today, I'll leave an update here about the outcome when I finish the job. I hope this information helps you.
Sep 27, 2008 | 2000 GMC Jimmy
The driver's side electric window stopped working. Will not go up or down. Passenger side works fine.
Each door has its own electric motor controlled by the switch the three possibilities are bad motor bad switch bad wiring.
Aug 02, 2008 | 2000 Dodge Ram 1500 Truck
Possible window fuse blown?
if the fuse is blown none of the windows will work,it sound wierd but all the power to the window motors runs through the drivers side switch. the drivers side switch may be your culprit.to be sure check to see if you have power goin in to the other switches before you replace the drivers side switch.
Jul 31, 2008 | 2002 Toyota Sequoia
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
