I am trying to sync tracks onto my son's Matsui 2GB MP3 player. I keep getting a message in Windows Media Player that it cannot synchronise the file. It says it is probably not a compatible file type but the tracks are all wma files. What am I doing wrong?
    Problem Solver:
  • 9 Answers
Download real media player mite it help you in sync...
Posted on Aug 17, 2008
SOURCE:
Philips GoGear HDD6330 MP3 Player will not sync music files onto it? How do I fix that and has deleted all previous ones! Please help>
This could be the player's connection mode in combination with your synchronization software. If you are using Windows Media Player or Philips Songbird to sync, the player will need to be set for MTP connection mode. Most other software that works with regular flash drives will need the player set for MSC connection mode. Whatever you are using, simply try the other mode.
To change the connection mode, select "PC connection preference" in the Settings menu of the player.
If you found this information helpful, please indicate as such.
Apr 12, 2010 | Philips GoGear HDD6330 MP3 Player
Sony walkman mp3 flash player
Download MEDIA MONKEY it's 100% better than media player as it will auto sync your player and gives you more options.
Just google it and download for free.
May 13, 2009 | Sony Walkman NWZ-B103F MP3 Player
Why can't I sync onto my mp3 player???
Well Basically you need to try and Refresh it if that does not work try formating it.
Apr 17, 2009 | Insignia Kix MP3 Player
Sync Notice
hook it up to your computer and allow windows media player to sync your mp3 player to the computer.
Apr 16, 2009 | SanDisk Sansa m230 MP3 Player
Sansa fuze 2gb some sync'ing some not on windows media 11
Go into Windows Media Player --> click the black arrow under the Rip tab --> Rip Options --> Format --> Mp3
Now re-rip the songs from CD
Delete the versions of the songs that you just ripped from your mp3 player
Now Sync the newly-ripped versions in mp3 format
You should be good to go now
-Tha Mp3 Doctor
Feb 01, 2009 | SanDisk Sansa Fuze MP3 Player
Auto deleting songs we wanted there argghhhhh!
If you are using Windows Media Player to synchronise the MP3 player, you need to change the Sync settings, from auto to manual.
If the Sync option is set to Automatic, then Windows Media Player will synchronise your PC and your player, so they have the same tracks. Unfortunately, if a track is deleted from the PC or the MP3 player, then Media Player will delete it from the other.
However, Media Player may have only deleted the tracks from its library, and not from the PC. If you go to My Documents ----> My Music, you can see if the files are still there.
The Manual sync setting allows you to drag and drop files from the Media Player library on to your player as you wish.
Assuming you are using Media Player, connect the MP3 player to the PC.
Open Windows Media Player.
Right-click the Sync tab and select Tools -----> Options.
Click on the Devices tab and select your player from the list then click properties.
In the window that pops up, click on settings, then click the button next to manual to change from auto.
Click on Finish, then close the other windows by clicking on Apply or Ok, until you are back to the main Media Player screen.
You should now be able to transfer your tracks manually.
If this doesn't work, give more details, including make and model of player, and the software you are using for transfer, and I'll try to help further.
May 14, 2008 | Audio Players & Recorders
help me please
Reformat the player in Windows Media Player - reconnect it to computer, open Windows Media Player, bring the drop down menu up underneath the Sync tab - click on the Player name, and then format.
Apr 16, 2008 | SanDisk Sansa Clip MP3 Player
On my matsui MP3 player
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Apr 12, 2008 | iLO (2 GB) MP3 Player
Mp3 Matsui 2gb
-Tha Mp3 Doctor
Mar 23, 2008 | iLO (2 GB) MP3 Player
Matsui mat 140mr
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 08, 2008 | iLO (2 GB) MP3 Player
59 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
