Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
New grease gun, never used. change mode switch from L to H will not engage all the way. Motor will not start.
  • 550 Answers
May not be a solution, just an idea
but the switch shits actual gears, the splines may not be aligned enough to allow the transfer.
put it back in low, run the motor a few revolutions to change the alignment of the gears, then try the shift again, like a crash box on a model T
Posted on Aug 17, 2008
My belt on my Jr z445 54 inch cut squeals when I try to go and engage blades and mower hesitates to go new belt and new plastic drive pulley
I would start with taking the belt back off and spinning each blade to see if it is binding, check under the deck for some wire or nylon twine that has become wrapped around some place, see if you can wiggle each spindle sideways looking for bad bearings ,there is a bearing on top and one on bottom of each spindle.I have found on a lot of deck bearings I have replaced they had grease zerks on the spindle but the bearings were sealed type and no way would the grease gun ever help. Let us know
Mar 24, 2016 | Garden
How much grease should I put in the electric motor?
First, make certain that you are using the recommended type of grease. Using a grease gun, slowly pump grease into the fitting until it begins to ooze out somewhere. Wipe off the (hopefully small amount of) grease that has oozed out, and you're done.
May 12, 2015 | Mercury Regatta 8mph Road Mobility Scooter
How to load grease in it?
The model 1056S will accept the standard grease cartridge available at any parts store. I have to use a razor blade and cut off the metal pull tab end. Then push the cartridge into the cylinder from the top. The real trick is to guide the rubber seal into the cartridge; it can be done, I load mine this way. Use the little lock to hold off the long plunger, allow just enough to work with inorder to insert rubber seal into cartridge. Only after the rubber is in the cartridge, then screw on the bottom cap. Then release the long plunger rod. You noticed that the plunger rod will rotate out of the rubber seal assembly, rotate it so the rod can be pushed into the cylinder without pushing the rubber seals. The sping will push the rubber seal to ensure grease is mover to the top. Very powerful PSI, do not blow out the rubber cups around the zerk fittings. Good luck
Jul 05, 2014 | Alemite Lever Gun Model 1056s
1985 20 hp is stif hard to move left or right
pretty common problem - you need to get some MARINE grease for your grease gun and shoot the pivot grease nipples- some models had a special nipple that needed a gun from the marina- (so you could not put auto grease there)
Move it back and forth as you shoot the grease. I have used a torch to warm up the bits to get the grease to flow.
Also- if the motor is new to you- they have a friction of some sort on them to keep them going straight when you let go- you might want to loosen that befor trying to fix a problem that isn't there.
Dec 06, 2012 | Boating
Motor noise loud squeal
on the motor there should be a grease nipple somewhere locate that un screw it and grease the motor with a grease gun
Sep 02, 2012 | Honeywell QuietCare 17450 Air Purifier
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
I installed a new grease cartridge in my grease gun and grease does not come out when triggered.
If the gun was working properly before you changed the cartridge, The gun is air-locked
Two things: 1. Make sure the bottom rod is pushed in. 2. Holding the gun by the handle on the top left of the gun, below the hose there is a little metal valve. Push that vent valve down and pull the trigger repeatedly until grease starts to come out.
If that doesn't work. Remove the grease hose, hold the vent valve down, pull the trigger a few times. Then release the valve and pull the trigger until grease comes out. Replace the hose.
And if that doesn't work. Sometimes when you put in a new cartridge the metal "washer" that actually pushes the grease up the cylinder will get caught at the bottom of the new cartridge. Make sure the washer will move freely into the cartridge.
That should do it!
Jan 14, 2011 | Lincoln Automotive Pneumatic Grease Gun...
AFTER GREASING BOTH UPPER BALL JOINTS ON 2006 GMC 2500--GREASE SPITS BACK OUT--INITIAL LOOKED TO BE OLD GREASE, I AFTER A COUPLE DAYS WENT TO REGREASE AND NOW THE NEW GREASE SHOOTS BACK OUT.
you don't want to over grease 2or 3 pumps should be good at every oil change but if it isn't taking grease in the zerk a Little tap on top may fix it or you should unscrew it and replace with new
Mar 12, 2010 | 2006 GMC Sierra
Is there a specific type of grease gun ad grease I
There is really no special grease gun to get. Any type of grease gun will work. I personally use a high temp. grease at the shop I work at. When greasing anything never over grease a joint , it causes a mess and will cause premature failure. All that is needed is three pumps of the grease gun.
Aug 16, 2009 | 1993 Lincoln Town Car
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
65 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Tyler Craig
Tyler Craig
Level 1 Expert
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
