Question about Microwave Ovens
I have GE mirowave The lights works and the turntable works. The fuse seem to be ok and all the capacitors or ok. I don't have a wireing diagram.Can you help? thanks
  • Microwave Ovens Master
  • 9,098 Answers
Any unusual noises? Is it louder or quieter than usual?
Here are some links you or someone you know can use for test help, but read their safety warnings first:
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We\'re happy to help you with free advice and we\'d appreciate your thoughtful rating of our answer.
Posted on Aug 18, 2008
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
Clock,lights and turntable work but does not heat
Open the microvave discharge the capcitors.If you don't know then stop here and call pro .
Open it First check physically the nothing is burnt.I everything seems okay then, check the resistance of the magnetron and also the fuse.PLEASE DON'T TRY IF YOU DON'T KNOW HOW TO DISCHAGRE THE CAPACITORS.
Please rate my work
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Everything seems to be working except food won't get hot
your 5kv fuse connected to the magnatron is probably looks like a white casing with two wires coming out of it..fuse is inside careful please
Apr 21, 2010 | GE XL1800 1100 Watts Microwave Oven
Turntable, fan, and bottom lights are not working, but microwave itself works. Is there a fuse that is common to these 3 items, and if so what kind is it and how do you get at it? - Thanks !
open up thye case and carefully discharge the h.v. capacitor after unplugging unit,there is only 1 fuse and unit wont run at all if this fuse is bad,then wiggle all the wire harness connections at all connection points,it sounds like a bad connection only
Mar 12, 2010 | GE JVM1440 Microwave Oven
GE Microwave JE2160 does not heat
Does it make any noises that it didn't before it failed?? It could be a bad secondary interlock switch, cook relay on the PCB, HV circuit problem or bad magnetron. You need an ohm meter to troubleshoot. If you take the cover off, you MUST short across the High Voltage Capacitor terminals to discharge any possible residual charge to prevent shock hazard.
Sep 11, 2009 | GE JE2160 Microwave Oven
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Not heating
you will need to take this in , unless you know what your doing
this is most likely the magnetron or high voltage capacitor but test will need to be done to ensure the rest of the circut checks out ok
Nov 06, 2008 | GE Advantium 120 Convection/Microwave Oven
Ge WES1450DM1BB serial RM913001U mirowave will not heat
Owners of any GE WES-series microwave might want to look at this blog post.
GE Customer Service is here. I would contact them.
No parts are available for this model besides the turntable parts. Scary...
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 21, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
