Question about HP iPAQ hw6515 Pocket PC
Hp ipaq quick gps connection driver
so what do we do with our phone if the gps connection files can't download? HELP!!!!
I needed to get my data connection with my phone company right so to download any data, then I could get the files.
You don't have to have those files, they only speed up the sattelite location process.
Posted on Aug 19, 2008
SOURCE:
I need a driver of my hp ipaq 514 voice messeger so i can connect my phone into a pc
You an download the driver from hp to your laptop / PC and connect the 514 via USB cable .the link is http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/swdHome/?sp4ts.oid=3360097&spf_p.tpst=swdMain&spf_p.prp_swdMain=wsrp-navigationalState%3DswLang%253D8%257Caction%253DlistOS&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken Cheers Brian
May 13, 2011 | HP iPAQ 514 Smartphone
HP Ipaq h1940 won't sync with Vista
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx). When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
Jun 01, 2009 | HP iPAQ H1940 Pocket PC
Hw6515 pda
Dear Phil,
its mean you have to update the GPRS Service.
there are 2 ways to downlaod the files, GPRS or internet
GPRS
1. click on the quick gps connetion icon, select setting.
2. select setting, then check the enable update and initial GPRS
3. click on icon and select download, it will connect to date service and download the files.
internet:
step 1 and 2 above
3. click icon select download while it on cradle.
also install the quick gps utility on pc, and add the quick qps connection into activesync list. each time you synchronize PDA the file will get updated.
For your second problem ,which is related to File Passward protections , its seems you had create these Worksheets on NTFS File system thatswhy they asked about the passward.
Regards
Mar 29, 2008 | HP iPAQ hw6515 Pocket PC
GPS working intermittently
With ref to the downloaded files. There are 5 sets of files on the server.
2 Day
2 Day version 2
7 Day
7 Day Version 2
All of the above appear to be updated once per hour although none of them now seem to work for me with Global Locate's version 1.19 software. There is also a 10 day version which seems not to be updated any more. There are notes on the internet that explain how to edit the registry to make the software point to an appropriate area for the correct file. If you are pointing to the 10 day version it might be possible to point at the 2 or 7 day versions and recover the situation. There are only two lines to edit but bear in mind all the warnings about editing the registry
Mar 25, 2008 | HP iPAQ hw6515 Pocket PC
Gps wont start
The ipaq requires a GPRS connection to download and refresh its GPS files every 2 days. Check the GPS symbol at the bottom right corner of the screen. It has to be blue. If it is grey, the GPS files need to be refreshed. Hp recommends MapAsia and it works, though the landmarks are not correct. The roads are ok. I do not know about diginav.
Oct 24, 2007 | HP iPAQ hw6515 Pocket PC
Hp ipaq6515
contact TomTom, they have been able to help me out by choosing the right settings. Good luck. And don't forget your charge, 'cause TomTom will eat your battery quickly.
Jun 10, 2007 | HP iPAQ hw6515 Pocket PC
Hp ipaq hw6915 gps not connecting
down load regedit and make some changes in the register so you will get an ikon GPS make the changes you will find i many forums and it will work
Dec 17, 2006 | HP iPAQ Bluetooth GPS Navigation
Hw6515 series and GPS
When connected with Activesync you can use your Internet connection on the PC. In the Activesync Window: Options/Rules/Pass Through - Connection: The Internet Then leave the PDA in the cradle and access the Internet on the PDA, works automatically ever after.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Ipaq Quick GPS connection file downloads
You may need to use the hard reset to make the quick gps connection working. but you will lost all ur program or data, including smart nav or tom tom. if you ready want to use the hard reset, remember to download smart nav or tomtom program. or you will end out no map in your system. good luck
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
684 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
