Question about Refrigerators
My refrigerator is not cold enough- freezer seems to be just fine.
  • stacemj Aug 18, 2008
    The vent on the fridge side is not pushing any air through, is that what you mean by evaporator fan?  How do I check the defrost thermostat?
    Problem Solver:
  • 15 Answers
Check to see if the defrost thermostat is working and that the evaporator fan is pushing air around!!!
Posted on Aug 17, 2008
  • Jon Gergeceff Aug 18, 2008
    In the freezer compartment there is a defrost thermostat that plugs into the heater..its a tube that runs underneath the evaporator coil....this is connected to the timer which tells the heater to turn off and on... there is also a fan by the evaporator coils called the evaporator fan...this is a different fan from the condenser fan underneath.. by the compressor.. I would take the cover off inside the freezer side and see how much ice is accumulating on the coils and check to see if the fan is moving in the freezer,, this is where the cool air in the box comes from..sometimes ice forms in the vents and impeads the air flow,, there are alot of great tutorials online if you can spare the time without the food going off..good luck
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
The top part is the freezer and it seems to be working fine but the bottom refrigerator part is not getting cold enough
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Refrigerators
Freezer seems to be working fine. refrigator does not seem to be cold enough
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 01, 2010 | Frigidaire FRT17G4B Top Freezer...
The freezer seems to be working fine but the refig doesn't seem to be cold enough.Do the freezer setting and the refig setter need to be set on the same number?
Normally what causes the refrigerator not to be cold enough is that the fan that pulls the air from the freezer is not working. Check to make sure it is working, if not then you will have to replace it.
No the freezer and refrigerator settings DO NOT have to be the same
May 25, 2010 | Maytag MTB1891AR Top Freezer Refrigerator
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
334 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
