Question about Mitsubishi WS-55857 55" Rear Projection Television
No Video or Sound
I have had this TV for seven years and it's worked fine until this weekend.  It started dropping out video segments of as TV show last night.  This morning it won't show anything (just blue screen).  I wired the satellite feed directly from the sat receiver box to the TV -- but nothing just blue screen. When I tried to access the TV's onscreen Menu (pressing the Menu button on the TV remote), the screen went all black -- when I hit that button again, it returned to a blue screen.  I toggle through all the input channels on the TV -- nothing changed but the channel ID in the upper left corner.  I can hear sound through my surround sound system -- so I know the sat receiver is working OK.
I think the TV chipset is dead -- Is this worth fixing, or should I just buy a new TV?
    Problem Solver:
  • 53 Answers
Hello Mabsab:
The repairs may cost starting at $ 75.00 to $100.00 for the estimate and basic trouble shooting the final cost of the repair may be about $200 to $400.00 dllars depending on the price of the part and the labor that is charged.
Posted on Aug 17, 2008
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
I turn on my xbox but nothing shows on my tv
Lots of reports of problems like this have been reported among xbox consumers. The xbox is actually kinda unreliable (look at the price drop lol). If you still have warranty take it back. It's probably fried and never will work again.
Aug 12, 2009 | Microsoft Xbox 360 Console
Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Feb 17, 2009 | Hitachi 50V720 Television
LS 3700 Leadsinger Microphone
We had the same problem just this weekend. However, we investigated it ourselves and discovered that you can take the microphone apart by unscrewing the two small screws inside the mic, under the music chips. Once the screws are out pry the two halves apart very carefully. Once we were inside, we discovered that the soundcard was loose and all we had to do is plug the sound card back in. Close 'er up and start up the show. Good Luck!
Nov 10, 2008 | LeadSinger LS-3000 Consumer Microphone
No video on tv monitor
To permanently fix the problem you have to send the unit to a programmer. A quick fix would be is to physically do it in your TV. While your Direct TV satellite receiver is ON, press the "TV/Video" or "Source" or "Input" button in your TV until the video will appear in the TV screen. All the TV has either one of this button.
May 18, 2008 | Universal Remote Control MX-3000 LCD...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Sony 36" tube TV
It definitely does not seem to be a problem with the Picture Tube. More like a cold solder. It is definitley not a job for a layman. Also, get a good technician to have a look, as locating cold solders is a labourous and time consuming process. It could also be possible that the main DC filter capacitor is getting dry, and may require replacement.
Aug 15, 2006 | Sony KV-27S20 27" TV
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
