Question about Dreamer Design Exec Lite Bike Trailer
Hitch Comes Out
Me and the kids really enjoyed this trailer, it was a lot of fun going on rides together, we do i say was?
Well he hitch keeps coming out, and i'm a bit scared about this, is there any way of solving this problem?
Thank you,
Have a good week.
  • 30 Answers
You can secure it with wire or you can drill throw it and add a safety pin.
I used the wire and it was good enough.
Posted on Aug 17, 2008
Tried to install a trailer hitch on 2010 Santa Fe
Take to a trailer hitch specialty shop. (Think of where you would take a pickup truck to - not U-haul or similar). This sounds like a severe safety issue. They will recommend a safe alternative to your current hitch and likely buy it back from you as well (at a loss to you I am sure, but better than killing yourself or others when your boat or jet ski comes zooming past you on the highway.)
May 02, 2014 | 2010 Hyundai Santa Fe
Can a hitch be installed on a 2003 cougar
Best solution for you call an RV shop and ask them. Most hitch shops will tell you sure you can do it. But can you you really? Ask the people that sell these things for a living they will what you can or can`t install for a hitch and what you can haul with it. Hope this helps
Mar 08, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
I have an 03 Toyota Sequoia, 4.7L V8, factory installed hitch receiver and wiring. The manual says it has a towing capacity of 6500 lbs GVWR. I have been towing a popup trailer weighing 3000 pounds with no...
I think the tongue weight rating on the stock hitch is 600 lbs, so you are over that. You probably want to level out truck to handle better when towing, so the best way is to get air bag helper that raises the back end.
Sep 20, 2010 | Cars & Trucks
I bought a Jetski and I want to tow it with my 03 Jaguar X-Type
Check to see if you have a local uhaul store. They usually have a hitch for any kind off car. If not , check Google for locating a hitch for your make and model.
May 30, 2010 | 2003 Jaguar X-Type
Both back brake lights burned out at the same time
if have trailer hitch - check for bare wires shorted together, if no trailer hitch look inside left frame rail at tail end- harness should come from front of truck to this point then cross over to right side- look for a cut or bare wiring again
May 21, 2010 | 2003 Chevrolet Silverado 1500
My trailer brakes do not work when the ball and trailer make a connection. But if I just plug in the trailer to the truck I can hear them working. I have checked everything and have had others look at...
Both the ball and the trailer hitch should be grounds so I'm guessing the trailer brakes have a hot wire touching the frame somewhere but not enough to blow a fuse. Before connecting the hitch to the ball, have someone press the trailer brakes and check between the hitch and the ball with a volt meter for 12 volts. If you do then something is wrong with the trailer brakes. I'm just guessing though.
May 17, 2010 | Cars & Trucks
I just bought an InStep® Joyrider Bicycle Trailer and the photo's are not very good. When attached is the bike trailer hitch supposed to attach perpedicular to the bike and the spring bends to 90 deg....
The hitch part that fastens to your bike rear axle has 3 pieces, a dimpled washer which goes on first then the hitch plate and a pin that holds the trailer to the hitch. Take off the axle nut (15 mm wrench) install the dimpled washer it goes on with the 90 deg tang facing the bike wheel and in the channel so it can't rotate. Then put the hitch plate on, mine faced down for the correct height, line up the dimpled washer with the bumps on the hitch plate to locate it properly. reinstall the wheel nut and be sure to align the wheel so it runs straight and true (I oopsed on this the first time) then attach the trailer, it is a 90 deg hook-up then you simply put the the pin in and you are good to go. The unique hook-up makes it so smooth and dampened that you don't even know it's behind you. We really love ours!
Apr 15, 2010 | InSTEP Quick & EZ Bike Trailer
Install trailer hitch wiring kit
Sould be a simple plug in harness under rear of vehicle
Mar 05, 2010 | 2006 Chrysler Pacifica
How to install a 3 point hitch on a 140 farmall did not come with a 3 point hitch
I think a 140 is a IH Cub . I don't believe they had available a 3 point hitch. Please register at www.farmallcub.com and there are people there that have had a 140 apart and back together many times. IF there was a 3 point hitch available they will know about it.
GOOD LUCK
Mike
Oct 16, 2009 | Garden
I am having having trouble in WA finding if i can fit a Haymanreese hitch to my 2007 Elantra
I checked the Reese site, and there is one available #77167 Insta-Hitch 1 which is a class 1 rating, drawbar #3594. Keep in mind that your Elantra is limited to towing 750 lbs WITHOUT trailer brakes, and up to 1500 lbs WITH trailer brakes. The installation of the hitch claims to be 'no drilling' but the exhaust system must be lowered for installation (then returned to position), and some 'trimming' of the cars fascia must be done. Take into consideration the terrain you intend to drive through. If there will be a lot of hills, you will struggle to accelerate, and braking w/out trailer brakes on long hills will overheat and reduce your stopping ability. Remember to figure in weight of passengers, luggage, and anything you put in or on the trailer, car roof rack etc. Good luck, and safe travel to you. Curt
May 04, 2009 | 2007 Hyundai Elantra Limited Sedan
Dreamer Design Exec Lite Bike Trailer Logo
110 people viewed this question
Top Dreamer Sport & Outdoor - Others Experts
Are you a Dreamer Sport and Outdoor - Other Expert? Answer questions, earn points and help others
