Question about HP Office Equipment & Supplies
I tried to default printer because, it showed printing 18 pages and I did not want it to print all now it is stuck with 1page 1/4of the page sticking out of the printer. What should I do ??
    Genius:
  • 1,056 Answers
Cancel all of the print jobs in the queue.
Open the printer, highlight the print jobs, right click and choose "Cancel"
Then turn the printer off, reboot your computer, turn the printer back on while the computer is rebooting.
That reset the entire printing process.
Posted on Aug 17, 2008
  • Coss Aug 18, 2008
    I wanted to add, while the printer is off, remove that page that is sticking out of the printer if you haven't already.
How to fix printing problem
Check your default printer. The printer may not be set as default setting.
Dec 11, 2015 | Lexmark X3430 All-In-One Color Inkjet...
Samsung scx 4720fn
If your printer has a menu option,try resetting to factory defaults.
Apr 17, 2014 | Office Equipment & Supplies
Printer does not print test page
Go to devices and printers, select the printer with check mark with right click of mouse. First check if the printer shows as default printer. If not, make it. Try test print.
Dec 22, 2013 | HP DeskJet Office Equipment & Supplies
Why i printing 1page show file name and title
Check options before printing. Look at the properties button next to the printer model when ready to print, and read all the options.
Oct 24, 2013 | HP LaserJet CP1515n Printer
My lexmark laser printer e120 prints smeared pages.please suggest how to solve the problem Thanks!
have you tried cleaning your infeed rollers as if sticking/slipping ( check for paper bits stuck within system ) print will be all over the page?? also you must have cleaned your print heads..
Jan 16, 2013 | Office Equipment & Supplies
I started to print a document and noticed it was 18 pages and canceled the printing. Now the printer won't print and the button next to the on/off button just flashes when I try to print something. What do...
I'm not sure why your printer stopped in the first place, but one reason why it won't print is because the print queue is blocked with old document requests.
Try going into your printer properties and remove all documents listed in the print queue.
(Start - Printer/faxes) - default printer - RMB - Properties).
May 16, 2010 | HP DeskJet 932c InkJet Printer
HP LaserJet 4 Plus Printer gets a paper jam every time
please try to check your print cartridge .... change the print cartridge to a new one , it should be the original type designed for the printer.
try also to clean the interior surfaces of the printer... you can use a blowing machine or use a brush to remove all dirt and stacked materials in the printer.
thanks
May 20, 2009 | HP LaserJet 4 plus Printer
Printer only prints one page of multiple page document
hi..
You may try to change the spool data format:
1. Click on "Start," "Control Panel," "Printers and Other Hardware" and "Printers and Faxes."
("Start," "Control Panel," "Hardware and Sound" and "Printers" for Vista...)
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark *** series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Try printing again.
Apr 24, 2009 | Lexmark P4350 All-In-One InkJet Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Ben Johnson
