Wireless Notworking hi!, I have a netgear wireless router.after 8 months now that router is not working...interet connection OK but wireless not working.... Can i repair it? I'm from sri lanka.... if any answer please send me to chathucj@gmail.com
  • bobbeghtol Aug 21, 2008
    router worked fine , then it wont let me connect to the internet
    signal strngth is only like 2 %
    have not moved ether pc's
  • 3,051 Answers
If you move the router around and see if the signal strength is better please keep me informed i have the same router i can give you a lot of different ideas that will work ok best regards mike
Posted on Aug 21, 2008
  • Michael Thomas
    Michael Thomas Dec 03, 2009
    Hello there i wasw just wondering if you have solved this problem
    please feel free to rate the solutionh i have provided
    best regards michael
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
In my lap with windows 8 version netconnection i s not available,but with same wifi modem..NETGEAR N150 WIRELESS D S L Modem Router mobile is net.connected.
Netgear are products that are last to just about 90 days. I am a computer tech and do a lot of house and business calls to TS networks. Most problems come from Netgear, once they switch to another brand, the problem disappear. Even I had a wireless Netgear router, and had to return it because the life span was about 4 month and the complimentary support is only 90 days.
Just by rebooting the modem (turning it off and on) usually fix it for about 8 hours, then the cycle start again. After rebooting the modem/router, delete your saved network from Windows 8 and start fresh. That should work.
Mar 21, 2015 | NetGear N150 Wireless-N ADSL2 Modem Router...
Netgear wireless wgr614 is configured and the ports wired connected and is working ok while wireless portion the laptop running vista says connection is limited and unable to browse
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Apr 07, 2010 | NetGear WGR614 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Netgear wg111 usb 2.0 won't connect even after clicking repair
Hi, Follow the steps below to configure settings:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Sep 02, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Laptop is sporadic in letting me connect to internet via wireless
hi,
Follow the steps below:
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
4. Highlight the SSID from the list that you want to connect to.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Aug 20, 2009 | NetGear WGR614 54Mbps Wireless Router...
Netgear Wireless Router WGR614 v9 CD Version 1.1 Poor Connection
if you go to the netgear site, and get to the section for your model, you may want to update the firmware. this may solve most of the problems. you can also read what the latest firmware fixes. it should give info on the entire firmware history.
Mar 29, 2009 | NetGear WGR614 Wireless Router
Wireless not working
Make wireless router is broadcasting signal update firmware if nesecary. Make sure wireless capability is on computer or make sure wireless card working properly by going to device manager.
Aug 17, 2008 | Computers & Internet
NETGEAR WIRELESS
More details are needed here, do you have mac address filtering on and is your router using dhcp or fixed address for your computers?
Jan 17, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
