Question about Epson Stylus CX6000 All-In-One InkJet Printer
Epson Stylus CX 6000
How do I stop the moving ink cartridge pac at the location where I am able to take out old cartridge and replace with new ??
  • docpreece Apr 03, 2009
    Which is menu button? I don't have anything so marked on my CSX6000.
    Genius:
  • 1,447 Answers
Hi-
There is an option on the control panel to change an ink cartridge after pressing menu button, go to maintenance and go to change ink cartridge. if you are having difficulties still, get back to me. thanks for using fixya. pls rate solution if it helps. keep me posted.
Posted on Aug 17, 2008
2 Suggested Answers
  • 125 Answers
SOURCE: Changing Ink Cartridges
I'm assuming you are using originals. I would suggest you taking the cartridges out and re-inserting them. If you are using refilled cartridges and you used the cartridges to almost empty then probably the chip may have short circuited rendering the chip useless. If you bought remanufctured cartridges I suggest you ask them for replacements. This isn't really that high tech but I hope this helps.
Posted on Aug 01, 2008
I just replaced all my inks and it is still telling me to replace my cartridges i also turned it on then off
  1. Open the scanner.
  2. Press the cp_button_14.gif Stop button to move the cartridges to the replacement position.
    Caution: Do not move the print head by hand; this may damage your all-in-one. Always press and release the cp_button_14.gif Stop button to move it
  3. Open the cartridge cover.
  4. Press down all the ink cartridges until they click into place to make sure they are properly seated.
  5. Close the cartridge cover and push it down until it clicks into place.
  6. Close the scanner.
  7. Press the cp_button_14.gif Stop button to begin charging the ink. This takes about 2 minutes.
    When the On light stops flashing and remains on, ink charging is finished.
    Caution:
    Never turn off the Epson Stylus CX while ink is charging or you'll waste ink.
    If the ink light flashes, press the cp_button_14.gif Stop button and press down all the cartridges securely.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 22, 2011 | Epson Stylus cx7450 All-In-One InkJet...
Empty ink cartridge cx6000
Hi there
Sorry I not think so most printer have to have all the inks in or not run
Feb 12, 2010 | Epson Stylus CX6000 All-In-One InkJet...
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
How to change the ink cartridge on an epson cx 6000 printer
Here is a link to your users manual, if you lost yours. Page 14 explains how to replace the ink cartridge.
http://files.support.epson.com/pdf/cx6k__/cx6k__pg.pdf
Hope this helps...
Sep 14, 2009 | Epson Stylus CX6000 All-In-One InkJet...
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
    If a cartridge is properly seated already, you may not hear a click.
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    E-90 error message on Epson CX6000
    If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
    If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
    1. Turn off the Stylus CX.
    2. Lift up the scanner.
    3. Press down on the ink cartridge cover to make sure it is completely closed.
    4. Close the scanner and turn the Stylus CX back on.
    Also
    If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
    2. Lift up the scanner to access the printer area.
    3. Remove the tape from the ink cartridge holder.
    5. Close the scanner.
    6. Turn the Stylus CX back on.
    Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    Jul 15, 2008 | Epson Stylus CX6000 All-In-One InkJet...
    New out of box!!
    If you already have tried reseating all of the inks and and inks are still not recognized, Please contact Epson tech support for a replacement ink or if they find out after some diagnostics that it is the printer that is having an issue they would be replacing your printer.
    Jun 22, 2008 | Epson Stylus CX9400 Photo Printer
    Help with Epson Stylus CX 6000
    Hi Open the cover then switch on the printer and then off from the mains when the cartridges are in the middle. Hope this helps!
    May 23, 2008 | Epson Stylus CX6000 All-In-One InkJet...
    I NEEED DRIVER OF INSTALATION OF IMPRESORA STYLUS CX 6000 PLIS MI MAIL IS marsa78_eva@yahoo.com.mx
    Jan 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
    Epson Stylus  CX6000 All-In-One InkJet Printer Logo
    184 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
