Question about Nokia N95 Cellular Phone
Any help I got nokia N95 from UK and I would like to used here in hong kong.I bougth new sim card here and I installed it,but it says no network found.I need your help
    Problem Solver:
  • 3 Answers
The phone has to be unlocked. There are several solutions for this.
Posted on Aug 17, 2008
Pls how can i flash my nokia N95
No matter what network your Nokia N95 phone currently runs on, you can unlock it---or "flash" it---to run on any GSM network. You will only be able to use your unlocked Nokia N95 phone on networks that use SIM cards---such as T-Mobile and AT&T---and not on CDMA networks such as Sprint and Verizon, which do not provide SIM cards.
Read more: How to Flash a Nokia N95
Unlocking the Handset
Remove the back cover and the battery from your cell phone. Locate a silver sticker with a bar code on it. Take note of the 15-digit IMEI number printed on it. At this time, also remove the SIM card and write down the numbers printed on the back of it. The SIM card is the small, white data chip in the silver cradle right next to the sticker. You will need these numbers to obtain your Nokia unlock code.
Request a Nokia N95 unlock code from your service provider. If they cannot provide you with an unlock code, you can buy one online.
Replace the SIM card, battery and cover. Fully charge your handset.
Turn on your handset and type "#PW+".
5
Enter the unlock code given from your phone company or website. Make sure you dial the number exactly as it was given to you. If you dial this number incorrectly three times, you will be permanently locked out of your handset.
6
Dial "+1#". At this point, the screen on your Nokia N95 should read "SIM Restriction Off."
Inserting SIM Card
Switch your handset off and remove the back cover and battery.
Remove the SIM card.
Insert the new SIM card into the SIM card slot. Now that the phone has been unlocked, this can be a SIM card from any U.S. service provider that uses SIM cards.
Replace the back cover and battery and switch the cell phone on. The screen should now read the name of the new service provider
Nov 30, 2011 | Nokia N95 Cellular Phone
Network problems
Your mobile may be locked to certain providers in hong kong and the phone would need to be unlocked, there are online services available for example
www.mobile2mobile.net
Sep 03, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Sim card not valid
If your Nokia N95 says Invalid Sim card means it locked to Some Network You need to Unlock it,then Only you can use with other GSM Network Sim card.you can get the Unlock code at here
Prounlocking.com/nokia/rs8wp8/ and Unlock it....Then Use with any GSM Network Sim card....
Sep 08, 2011 | Nokia N95 Cellular Phone
I want to use my Nokia N95 sim card in my new unlocked nokia 1661. Is this possible? I have put it in but it keeps asking for Sim card still.
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.mobile-unlocker.com/nokia-n95/rs2wp9/
Sep 18, 2010 | Nokia 1661 Cell Phone
Whenever i want to install a software downloaded from the net, it shows certificate error? what can i do??
You need signed applications(nokia 5800 compatible Applications
1) Make your phone memory backup data using nokia pc suit 7.1(very important)
2) After that remove your Micro sd card from mobile..
3) Remove your SIM card also(very important)
4) press *#7370# and unlock code to format your phone memory(yap.. this is safe default is 12345)
5) You will lose all your important date with this action...so make a backup of your phone memory
6) Now nokia 5800 xm will reboot.....wait for a minute....
7) Then select your country region as "Hong Kong"
Cool Set the current time......(set your phone to offline mode)_
9) Now you can put that Micro sd card ......
10) And don;t insert that SIm card right now...just wait....and try to install any supported singed application (E.G-nokia handwriting calculator)
11) And you may install any singed application ......
12) After that just install your Sim Card.
Apr 26, 2010 | Nokia 5800 XpressMusic Smartphone
Enablig Gprs and MMS of ka08 mini cell phone touchscreen brand
try swapping into the other sim card slot because it did that with me
Feb 16, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Unable to change language settings to English
the phone selects the language according to the information on your SIM card so I would request a new sim card from my service provider in english
Sep 30, 2009 | Nokia E52 Smartphone
Nokia n95 8gb lcd is blank but i hear it's turning on
if its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
May 30, 2009 | Nokia N95 Cellular Phone
Want to use nokia 580 on verizon USA but phone from Hong kong
No, Nokia 5800 is a GSM phone and Verizon uses CDMA. The technology is very different. Although some of Verizon phones also except a SIM card, they are in use only when their customer travels outside of the USA.
Apr 28, 2009 | Nokia 5800 XpressMusic Smartphone
Unlock code N95 8GB on 3uk network
you cannot unlock this phone remotely, you need to have a universal sim or turbo sim so that you can use it to other network.. go to universal-sim.org for more info on this sim
Oct 08, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
