Question about LG Washing Machines
Lg washing machine trips out and displays le on screen. WM2277HS
  • 770 Answers
LE= Locked Motor Error
Here are the causes
• The connector (3-pin, male, white) in the MOTOR
HARNESS is not connected to the connector
(3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors
(3-pin, male, white) in the MOTOR HARNESS
and 4-pin, female, white connector in the MAIN PWB
ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR
ASSEMBLY and MAIN PWB ASSEMBLY is cut (open
circuited).
• The hall sensor is out of order/defective.
Posted on Aug 17, 2008
  • Gary Davd
    Gary Davd Aug 17, 2008
    Sorry was it a small " le" if so please check the water inlet valves for a blockage. shut water off and remove hoses from machine there are little screens inside that need to be cleaned out
I have an LG wm2277hs washer, started to flash LE code now it will not power up
Le error is a motor error code. The motor error could be caused by several things including : motor, bearings , rps sensor and wiring and in some cases all. continued use with this error could have taken out your mother board.
Dec 13, 2015 | LG Washing Machines
How do I fix my washing machine
If your washer was working previously please read below.
Thermal Overload Protection
Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Jan 06, 2015 | Washing Machines
My lg model wm2277hs won't rinse water stays after washing
you need to ck the filter in the front down at the bottom left corner of the washer if it is clean you will need a new drain pump motor
Nov 02, 2012 | Washing Machines
Mt LG washing machine (model wm2277hs) displays an error code containing an upside-down "F" and an "E". What part(s) do I replace?
Replace the thermistor, part # 6322FR2046C
It is located right next to the heating element at the bottom front of the outer tub. (just below the door gasket) It is very difficult to replace without removing the front panel.
Mar 03, 2011 | LG WM-2277HW Front Load Washer
I have a LG TROMM WM2277HS front load washing machine. Error code UE displays when there is 3-5 minutes left in the cycle. I have tried rearranging the load, making it lighter or heavier. I have also ran...
Hi.. UE error means unbalance error..Check your floor level and machine legs... after u checking ur floor level and legs also perfect means change the suspension rod.
Sep 25, 2017 | LG WM2277H Front Load Washer
Code "LE"
Here is a tip that will help you understand the LE code...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 21, 2010 | LG WM0642H Front Load
Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Sep 14, 2009 | Washing Machines
LG WM2277HS error code LE
This is from the service manual for your washer. The hall sensor may be defective but you will need a technician to check out the other things listed here. The sensor is not covered for 7 years. Good luck
Go here to learn how to install ~ http://136.166.4.200/contents/Laundry/WM2432/WM2432xx_Service_Manual.pdf
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
Feb 25, 2009 | LG WM-2277HW Front Load Washer
Lg wm2277hs
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Washing Machines Logo
131 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
