Question about HP Office Equipment & Supplies
New HP C5180 A-in-O printer/scanner. Scans and prints photos perfectly. Prints docs and photos from computer main disc great. Won't scan and save to computer anything! Why?
    Genius:
  • 1,447 Answers
Hi-
You need to install the scan driver, click on this link and choose your Operating system and install the scan driver, click HERE
hope this helps
Posted on Aug 17, 2008
Why won't my HP Photosmart 5510 copy?
first you confirm scanning is working or not if it is working fine there is no issue with printer, if it is not working problem found with scanner assay you need to contact hp service center....
May 04, 2014 | HP Photosmart 5510 Wireless e-All-in-One...
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
Jun 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
HP c5280 only prints green photos. All other printing is fine. I have put in new hp ink and photo paper. I have tried printing both from computer and with computer unplugged. A print from a website on...
This Problem is based on the Color Management so , The Perfect Solution for this problem is open the Photo or image etc in Adobe PhotoShop then goto Enhance->Adjust Color->Remove Color Cast , after removing the color cast , create a new layer for adjusting brightness , contrast & etc , then finally goto Image Size and change the DPI from 72 to 300 then save the image as JPEG or PNG etc , after saving the image close the Photoshop and open the image using Windows Photo Viewer and take the printout which will come as it is in the System
May 23, 2011 | Office Equipment & Supplies
My Epson Perfection V500 Photo won't scan any negatives. It scans them as photo's. I've removed the document mat, unlocked the lock, connected the cover cable and adjusted the software settings. I can't...
I don't know of any regular printer that scans negatives. Check your printer manual to see if it's designed to print negatives. You can get devices that will do that, but I'm not certain any regular printer will. If you don't have a manual you can look up your model online to find out more.
Oct 14, 2017 | Epson Perfection V500 Flatbed Scanner
My scanner when it scans there are little lines accross the picture it does not matter if I print it straight out or save it anything scanned HP photosmart c5180 all in one any thoughts
if the lines are in the direction of paper feed, the problem is probably dirt or ink from ball points on the glass. Against the dark background it is very hard to see. Try alcohol on a clean cloth and scrub the glass vigorously.
It could be that the ink cart are getting plugged up or just needs replaced.
Nov 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
I want to scan a picture onto my laptop i connected the cables and evrything. ir prints fine. but it dosent want to scan and my printer is a dell 924
Did you install the full software (if available for your OS) before connecting the cables? Were you trying to launch the scan from the computer or the scanner? The scanner buttons will not work unless the full software is installed and the monitor program is running.
If you installed the generic OS driver, uninstall it and then unplug the data cable. Then download and install the software from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1153481& . Select your OS and click Next then click on Drivers. Start scans from the computer first. (HP Solution Center has destination buttons that need to be set before the buttons on the scanner can work. Once you scan from the computer, you will have a better idea of the settings you should use as defaults for the buttons.)
Try connecting the printer directly to the computer, if you use a USB hub or print server. Also try a new USB cable. The scanner requires bi-directional communication and thus can fail even if the printer works. Your cable should be 6' or less in length.
WinXP, Vista and Win7 have options for scanning without the HP software. However, they do not work with the scanner buttons. Launch Paint (Start > All Programs > Accessories > Paint) and select File > Import from Camera or Scanner > From Scanner in any of the listed OS versions. Vista and Win7 also include Windows Fax and Scan (New Scan). Vista has included Photo Gallery that also can acquire Scans (this is available for Win7 as part of the Windows Live package download).
I hope this helps.
(additional information can be obtained here: http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=1153481 )
Nov 09, 2010 | HP Photosmart C5180 All-In-One InkJet...
Scanner will not scan to image only printer or memory card
If you are using Windows 7, check www.hp.com for an update on the appropriate driver download page - there is a know issue with the driver software that prevents scans from being saved anywhere.
Jul 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
Scan photos to computer
You need a scanner to scan the photos. I have a canon scanner and it works pretty well. That printer does not scan photos. it just prints them.
Apr 22, 2009 | HP Photosmart D7160 InkJet Printer
Scanner, scans and then re-scans.
you can go direct open my computer then you will find in the my computer window icon for HP officejet 4300 if you press it you can go ahead with wizard that let you scan your photo or document fast you can even send short cut to this icon at the desktop so you can reach it faster
 OR   ~~~~~~  another solution
when you open the hp software press the scan botton then will open another window has two option choos scan and then choos scan again in the other window
Please rate me if this solution was ok thank you
Oct 15, 2007 | HP PSC 1315 All-In-One InkJet Printer
Seeker5211
Seeker5211
