Question about KLH DVD8350 DVD Player
Loading The player continues to load, then says No Disc.
  • 3 Answers
Remove cover. move lense outward with finger. Clean lense with rubbing alcohol or eye drop fluid. Wipe dry with other end. Works great now
Posted on Jan 04, 2009
SOURCE:
Player reads DVD as bad
Are you using the correct format disc.If you are playing a blu ray disc in a non blu ray player the player will not read the disc
Jan 02, 2018 | Durabrand Audio Players & Recorders
The cd player do not spin it comes on then go off
Hello
The sled motor of your player is not working. This is the motor that spins the disc inside as soon as it has been loaded. But to spin disc, the disc must be loaded properly into the loading mechanism. Just check the loading belt that attached with loading motor and loading gear set for any loose, which may cause improper disc loading. Replace it first. If it does not help you, check the voltage at the seled motor terminals. There must be a voltage [4.5VDC approx:]. If the voltage is there and still the sled motor does nor work, replace it. If voltage is not there, the fault is with the loading IC which is soldered to the main board of the device. OK>
Jan 05, 2012 | Lenoxx Electronics Audio Players &...
Insert dvd but comes back saying no disc inserted
Hello
Your DVD players loading mechanism has some fault with it. It does not load the disc properly in, Check the loading belat first, and the loading motor for low pulling power. Check whether there is any fault loading gear wheels. The fault is clearly of the loading mechanism itself. OK.
May 18, 2011 | Pioneer Televison & Video
Says loading disc then no disc pops up and it just won't play. Tried the phillips lense cleaner still does same message (loading the no disc)
The reason the player keeps loading and showing no disc is simply because the lens of the player is weak.
To fix this,
  1. Open the cover of the player with the appropriate screwdriver,
  2. Open the disc tray,you will see the lens, like a crystal or diamond like object,
  3. Replace the lens by removing it with the mechanism that supports it and fixing the new lens,
  4. Test it with a DVD disc.
  5. Cover the player back.
Take care
Jun 21, 2010 | Televison & Video
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
Problem loading disc
just open the loader and replace the lense.
Jul 23, 2008 | Dynex DX-PDVD7 Portable DVD Player
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
KLH DVD8350 DVD Player Logo
167 people viewed this question
Top KLH Televison & Video Experts
Steven Wander
Steven Wander
josepovedaca
Level 1 Expert
ray gallant
ray gallant
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
