Cable output connector is loose - Televison & Video
    Problem Solver:
  • 53 Answers
Hello Yatra:
It sounds like the connector screw for your coaxial connector is lose. This can be resolved by opening the back of the unit up and just tighten the screw or the soldiering may to be resoldiered.
The Slash
Posted on Aug 17, 2008
No input signal
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya!
Since you had it repaired and transported it home this fault may be due to a loose connection. Or like you say it could be a simple task of placing the graphics cable in the correct graphics output port.
Install the monitor graphics cable into a horizontal graphics output port if possible. Doing this would therefore connect to the Graphics card if one is installed.
Plugging the monitor graphics cable into the vertical graphics output port would mean that you are connecting your monitor to your computer's onboard graphics output. Which will not work if there is a graphics card installed, in which case one must use the horizonal port, found on the graphics card.
If you have checked that the monitor cable is correctly plugged in and your problem continues then one checks the following:
NB: Turn off your Computer before doing the following:
Make sure the graphics card is secure in it's slot, push down on it lightly when the PC is off.
Check that the power connector to the graphics card is inserted: if applicable.
Ensure that the power supply connectors going to the mainboard are seated.
Check the Memory modules, one may need to be seated or cleaned. Clean the gold fingered connectors with tissue paper.
You may also find it of benifit to look at on eof my published works, entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Take care!
Feb 10, 2012 | HP Pavilion Computers & Internet
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
My RCA RTD325W system only plays DVDs in blue, yellow and white. Why? All of the connections seem to be hooked up correctly.
Please check the connections according to the used video analog output with the figures below:
Composite video output (yellow connectors cable)
josema_sv_4.jpg Component video output (red, blue and green connectors cable)
Mar 18, 2011 | Audio Players & Recorders
How do i increase my graphics card performance?
Instruction:
To troubleshoot video issues, follow these steps and test your video after performing each one:
  1. Check the video signal cable connector for bent or missing pins. Check the cable for cuts.
  2. Check to see if moving the monitor connections slightly causes color changes. Tighten loose connections.
  3. In the case of systems with multiple video output connections, verify that the correct connection is being used.Some systems ship with two video connectors on the back, however only one is enabled.
Feb 25, 2011 | Computers & Internet
GET SOUND BUT NO CLEAR PICTURE ONLY HORIZONTAL LINES form bottom to middle black blur lines
Video output section of your tv is in trouble. Either it not gets proper voltage [low voltage if voltage is there]; or video output Ic or transistors whichever used may got damaged. Never switch on the tv in this condition; that picture tube may get damaged. Get it repaired soon.
Oct 14, 2010 | Philips Magnavox 20MT133S 20" TV
Finding a JVC camcorder A/V output cable
Fixya does not sell spares or accessories. Were these items not included in the package when you purchased the camcorder ? They should be available either from JVC Spares themselves, or on Ebay
Mar 28, 2017 | JVC GR-D290 Mini DV Digital Camcorder
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
I want to connect the z2300 speakers to an LCD tv. Do I need a special cable?
try to check your speaker if what type of cable your speaker have...your LCD tv i think its a RCA connector, so you have to insert the RCA connector to the output audio label,,,then the cable which is also an RCA output must be connected to a RCA female connector ....again the output the your female connector will depend to what your speaker output have....it its minijack or RCA then the output must be female RCA of mini jack also.
Oct 19, 2009 | Logitech Z-2300 Computer Speakers
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
